Hi to all I'm new to this forum and need some help,
I have bought about 1 years ago a new motor and a so called "union graduate remote pendant" for my Myford super 7 lathe. The Teco 7300CV Inverter I had bought some time be for.
I found now the time to install all this to my Myford and it works all fine FWD and Stop are working, BUT the Revers switch on the pendant will not work.
I put all the parameter I got with the remote pendant in to the Teco 7300CV but no Revers.
Revers is enabled set to 0000
Set to 3- wire control 0002
Parameter 5-00 0000
Parameter 5-01 0001
Parameter 5-02 0002
(But in the Manuel is written "As 3 wire control mode is selected, the terminal S1, S2 and S3 is not controlled
by 5-00, 5-01 and 5-02."!)
When I switch from the Teco it self in to REV it will work fine.
If I push the Rev from the remote pendant the rev light will blink on the Teco ( only as long as I press the Rev) but nothing will happen.
If I press first the REV and than the FWD button and hold the REV button the motor will start running in REV. When I release the REV button the motor will stop running.
I hope some one can help me to solve this problem. I add some photos from the wiring of the Teco and the pendant.
The white cable is 24V (PNP on the Teco selected)
yellow is S1
brown is S2
blue is S3
Thanks Olaf
http://www.model-engineer.co.uk/sites/7/images/member_albums/96538/imgp0038 (3).jpg
http://www.model-engineer.co.uk/sites/7/images/member_albums/96538/imgp0039 (2).jpg
http://www.model-engineer.co.uk/sites/7/images/member_albums/96538/imgp0040.jpg
Parameter 5-00 0000
Parameter 5-01 0001
Parameter 5-02 0002
yellow is S1
brown is S2
blue is S3
Thanks Olaf
