I am an electronics novice (took Control Data's micro electronics course way back in the mid 80's and never used the knowledge gained) trying to build a circuit to power LEDs using a windmill and a micro generator.
Generator Specifications:
Output voltage : 3V-24V
Output current : 0.1A-1A
Rated power : 0.5-12W
Rated speed : 300-6000 rev/min
The Led's I'm wanting to use are:
5mm LED Diodes round head and clear lens
Wavelength Range:
Qty
(2) Red: 620-630nm
(6) Blue/White: 460-470nm
I'm rather clueless on how to create a stable voltage and current to these two sizes of LEDs with a supply current that varies based upon the strength of the wind.
Also, I've been comparing the pros and cons of series verses parallel circuits and am leaning towards parallel thinking that if a bulb fries, then the rest of them would still be lit. I understand that I would need a certain sized resistor in line to each of the LEDs in a parallel circuit but that's okay with me.
Any help would certainly be greatly appreciated.
Wavelength Range:
Qty
(2) Red: 620-630nm
