I need to maintain a half-full 55-gallon drum at 180°F?
Dave Gahl
Jan 16, 2018
I'm working on a project for work and need to fill a 55-gallon drum half way and maintain it at 180°F. Right now I was thinking on using dishwater heating coil. Typically how much voltage does one of these need to run? Does it vary by brand?
AnalogKid
Jun 10, 2015
3,058
Fill with what?
Dishwasher heating elements are designed to run straight off of a country's AC grid, so 120 Vac in the US.
How tight does the temperature control have to be? Omega Engineering and other industrial supply companies have lots of thermostats with sensors.
ak
Alec_t
Jul 7, 2015
3,821
If uniformity of temperature is important you will need a stirrer of some sort.
Good thermal insulation around the drum will help with the uniformity issue and to minimise power consumption.
What will fill the drum?
Alec_t
Jul 7, 2015
3,821
Get an element which is food-safe (stainless-steel sheathed?) and has an easy-clean shape.
duke37
Jan 9, 2011
5,364
If smaltz is gloop, then I would go for placing the drum on a hot plate and fix a contact thermostat to the outside, then the inside can be cleaned without obstruction
A hot water immersion heater close to the bottom with a built in thermostat would do the job but would be difficult to clean out.
