IC Help
rybitski
Jan 9, 2006
161
I want to learn to use IC's... I have looked around on the internet and I can't find many resources... If you know of any sites or would care to explain some basics I would greatly apreciate it...
ante1
Jan 24, 2004
4,138
Hi rybitski,
What do you mean use IC’s, TTL, digital, analogue, microcontrollers ?????
rybitski
Jan 9, 2006
161
I don't know. I know very little about IC's and not enough to know the difference between them. I have used a 555 timer in one of my projects before, I got the directions ofline. It worked, but I don't know why or how it worked.
This is a very vast topic I know...
Is there a beggining to start at?
Staigen1
Oct 26, 2003
695
Hi rybitski
Start by learning electronics, there are many good books right here on this site!
In the "Articles" area, and also here in the postings, many of then uploaded by Ante. Good luck!
//Staigen
ante1
Jan 24, 2004
4,138
Hi rybitski,
As Staigen suggested, find a “starter” book and get right in to it!
And maybe you should take a look at this site too:  http://www.ibiblio.org/obp/electricCircuits/
You will find six good books to download free, this will give you a good start!
Please let us know how you are getting on and: Good Luck! ;)
rybitski
Jan 9, 2006
161
Thank you very much for that site, I think it will be very useful...
tadgesualdo
Dec 21, 2005
23
rybitski,
It is true you must understand basic electronic theory to understand how to utilized IC's in circuit, especially if you want to design with them.  But even then you will not totally understand how or what is going on inside them fully.  So I found it helpful to view them as black boxes, if you give the correct inputs, you should get the desired outputs.  Therefore often times when you can't figure out why your circuit is not working properly, and you have checked that all required input information (supply voltages and input information) then you have not other choice but to assume that the black box (in this case an IC) is not working.  The more complex the IC becomes, or the more pins it contains the more this way of thinking and trouble shooting is helpful I have found.
IC's can really make electronics fun and a lot less work, but they come with limitations as well.
Enjoy,
TG :)
