Hi guys. I have made a circuit that uses a UC3843 in order to run a 12v lamp and be able to dim the lamp.
I can get an the voltage on PIN 1 of the chip (the ouput of its error amplifier) to vary between 0.8 and 7.26 volts (which I believe should be enough to vary the output duty cycle between 0 and about 96%). However the output on PIN 6 is only varying between 0 and 0.13 volts (not the so called 12v for a high output).
My question is are there any common sort of reasons I can look for as to why this output is so low?
