IC question
Sugar1
Mar 7, 2004
7
hi guys... im a newbie and im so confused by this.. pls help
.. if an IC has 16 pins.. and only 4 pins are needed... does this mean that the 12 ramaining pins are useless?... and all i could do about them is give them a hole?
i meant... putting an IC on a pcb that has 16 pins.. and only 4 is needed... what will i do for the remaining 12 pins?.. should i still make a hole for them with a ground on their own?.. or just a hole without any grounds.... THANX!
mixos1
Administrator
Jul 13, 2003
581
You just put them in isolated from the rest of the circuit pcb holes to stabilize the IC over the PCB. Nothing more - nothing less.
Also you can cut this pins and make no holes for them.
What IC is this?
Sugar1
Mar 7, 2004
7
its an 8030 sound IC for touch sensitive alarm... :) :)...
... thanx for the reply.. :)
billy2
Oct 23, 2003
101
Yes, just drill the holes and leave the pads unrouted...
MP1
Dec 7, 2003
3,399
For some time I was making sure that I had the 4 corner pins for anchors and I left the other unneeded pads off my drawing as they were not needed. However, later I found that this was confusing to others as to which IC was there and left me the problem of making special parts drawings in the cad programs I used later on. Finally, I just left the package as is, drilled the holes and simply did not route the pads to anything as Billy has mentioned. Sometimes we make more work for ourselves in trying to eliminate some work.
MP
