Hi everyone,
I’ve been working on a small DC power setup recently and started thinking about something that doesn’t seem to get discussed very often — long-term reliability of connection points in higher current systems.
In my case the system is fairly simple: a battery pack feeding a DC load through a controller. Current is not extremely high but it can reach around 30–50A during peak load.
Initially everything worked fine, but after running the system for some time I started wondering what usually becomes the weak point in these setups.
Some things I’ve been thinking about:
For example:
Bolted terminals seem very solid but can loosen with vibration.
Crimped connections are simple but depend a lot on proper crimping tools.
Plug connectors are convenient but I wonder how well they hold up under continuous current and temperature variation.
So I’m curious how people here approach this in real projects.
When designing a power system that may run for years, what connection method do you usually trust the most?
Is the key factor mechanical stability, contact area, or environmental protection?
Would appreciate hearing some real-world experiences.
Thanks.
- Do connector contacts degrade significantly over time with repeated thermal cycles?
- How much does vibration contribute to connection resistance increasing?
- Is corrosion or oxidation a common issue in real systems?
For example:
Thanks.
