Identifying equivalent for surface mount diode from photo
Narna Peel
Sep 16, 2017
3
Hi
Please would someone advise me on an axial replacement for the surface mount diode shown in this photo.
Also would you confirm that the resistors shown in the photo can be replaced with an axial 470 ohm resistors.
Thank you
Narna
kellys_eye
Jun 25, 2010
6,512
The diode can be replaced with a standard 1N4004 and any axial resistor will replace the fixed values SMD device (check the wattage - can't make out what size package those resistors are but the equivalent may be 1/4 watt or 1/2 watt...)
Narna Peel
Sep 16, 2017
3
Brilliant, thank you.
kellys_eye, would agree with davenn that the resistors are actualy 47 ohms and not 470 ohms as i thought?
The fact that nobody has contradicted Dave is probably a good indication.
Narna Peel
Sep 16, 2017
3
Ha ha, sorry Dave, I did not mean to insult you.
I appreciate your knowledge, it has just saved me a lot of time.
kellys_eye
Jun 25, 2010
6,512
If my opinion is that highly valued :p and it winds @davenn up a little then yes, it's a 47Ω resistor!
