IDTech monitor IBM
GregS
I got a monitor here i wonder if anybody has worked with. Its a very high resolution 22.5
inch. I need another power supply I think. Can't find any documentation, Sony bought the
company out and closed it down, cause the technology was too advanced. So I
have a 200 dpi $10,000 monitor I need documentation for, namely the power pins.
Model MD22292-B2 or IBM 9503-DG1/DG3. I don't know if Sony ever sold this model
and used another #. Its a 6 pin connector.
greg
GregS
resolution 22.5
bought the
model
I had IBM looking up #s but the docs listed on the website are not available.
Luck, I found the old broken supply. Things listed at 16 volts 10 amps.
Probably uses all 6 pins.
greg
James Sweet
available.
greg
You probably won't find documentation. Just fix the original power supply,
any competent tech should be able to.
GregS
I don't think i would try to fix it. Its the second one that failed.
Someone sent me the docs info.
greg
GregS
Maybe I will try to fix it. Such a hard deal trying to find another 16 volt supply. I
found one for $300. The IBM is on back order @$150.
Delta supply used in IDtech IBM model, now Lenovo, but monitor not
available due to Sony.
greg
GregS
Well here's another thought. Couldn't you just get two 16v 5 amp SMPS for a
laptop and wire them in parallel? I've never seen it done, but I can't see
why it shouldn't work any different than wiring 2 batteries in parallel.
Mike
16 volt supplies are hard to find. I did find one by Acopian for $270.
I can get the orginal with some wait for $150. I looked at the supply
and its varying voltage constantly resetting. Nothing obvious I
can find.
greg
James Sweet
can find.
Did you check the ESR of all the electrolytic capacitors? That's where I
start when diagnosing switchmode power supplies.
Probably doesn't have to be 16V exactly, 14-20V or so would probably be just
fine, but I don't think the original supply should be hard to fix. If you
don't know how, take it to a tech who does.
Tim Phipps
can find.
greg
A lot of IBM laptops use 16V power supplies.
GregS
I didn't check the caps. I'll give it a shot. The supply is on order, but
that might be a problem since its not in stock. The logic seems a bit too complex
to troubleshoot without a diagram. You would think that the problem is likely a heat
overload problem.
greg
James Sweet
complex
likely a heat
overload problem.
greg
I wouldn't. I would think the problem is likely bad capacitors, I see it all
the time, probably 80% of SMPS problems.
GregS
isn't that the major cause of capacitor failure ?
greg
James Sweet
greg
They fail for a variety of reasons, age, heat, electrical conditions, there
was a large batch with defective electrolyte.
Usually when they start to go, they work better as they warm up.
Sam Goldwasser
can find.
Did you check the electrolytic capacitors? (Sorry if I missed this
in a previous reply.)
There are 15 V power supplies on eBay. Some may have enough adjustment
range to give you 16 V if that is absolutely needed.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
GregS
I got my ESR meter and will check today.
The OEM supply has a coaxial looking supply cord. It has a little red
wire running through the center bundle for a sense line. I don't see
anything like that often.
greg
