Incandescent lamp inrush current vs. regulated power supplies
Allan Herriman
On Mon, 4 Feb 2013 18:32:25 -0600, "Tim Williams"
message Some switchers current limit and some "burp", namely shut down
quickly on overload and try again later, a few times per second
maybe. The latter don't pull up loads very well.
I've had that problem with USB 5-volt supplies, especially when
driving electronic loads that have switchers - negative impedance -
loads inside.
I find they work better. A [continuous] foldback limit is guaranteed
to get stuck forever, each and every time the load is the same.
That's boring, and dangerous besides.
Switchers don't need to fold back, and I haven't seen one that does.
Some switchers do need to fold back.
Here's why: (Assuming a steady output current) at low output voltages
the duty cycle will be low. This means the synchronous rectifier fet is
carrying a much larger RMS current than it normally would at full load.
Adding foldback to reduce the output current when the output voltage is
low can save money on thermal management for the lower fet in certain
designs.
But foldback will further reduce output voltage (not current) putting
you right in that box.
In some situations, that may be true. In others, untrue.
For the OP's load with negative resistance, foldback is a bad idea.
For the general case, it may be possible to design the load to draw low
current at low voltage, e.g. by means of a UVLO. In that case foldback
current limiting doesn't cause system problems at all if the UVLO
threshold is higher than the voltage at which the foldback current limit
kicks in.
Regards,
Allan
loads inside.
designs.
I don't see a case where it's wanted (for a switcher).
kicks in.
The above doesn't make any sense to me. If the load/PS are designed
for, say, 10V, how is the voltage going to decrease *and* the current
decrease?
josephkk
kicks in.
Regards,
Allan
Not sure where you first saw this thread but OP in sed has a lamp load.
As follows:
Allan Herriman
I knew it was an incandescent lamp. I understand the static and dynamic
VI characteristics of such a load, and their implications for driver
design.
My negative resistance comment was the result a brain fart - I was
thinking about a completely different system with a DC/DC converter as a
load and somehow got that mixed up in my post.
Allan
Allan Herriman
On 05 Feb 2013 12:06:25 GMT, Allan Herriman
<[email protected]>
loads inside.
guaranteed to get stuck forever, each and every time the load is the
same. That's boring, and dangerous besides.
is carrying a much larger RMS current than it normally would at full
load.
is low can save money on thermal management for the lower fet in
certain designs.
As I said earlier, it can save money in certain designs.
It would only be useful under the following conditions:
- the usual duty cycle of the DC/DC converter is quite high (i.e. Vout/
Vin is close to 1). This in turn means that the bottom FET can be quite
small compared to the top FET.
- The load doesn't need a lot of current at low voltages.
- The design must tolerate short circuits on the output.
- There is no hiccup or other mechanism to protect the bottom FET during
a short.
During a short on the output, the duty cycle will drop to close 0. The
bottom FET will be on most of the time, conducting the full output
current. This is the worst case for the bottom FET. Its power
dissipation may be several times what it is for normal full load.
The top FET, OTOH, has a fairly easy time during an output short.
The designer has a choice: size the bottom FET (and its heatsinking) for
this worst case, or reduce the average current somehow. Often the
average current is reduced with a hiccup (periodic shutdown and restart)
but it is also possible to use foldback current limiting.
For the small DC/DC converters I usually design, the FETs are cheap and
there is no heatsinking, and I have never used foldback current limiting.
I have seen it done on larger designs (by other people) though.
decrease?
UVLO stands for Under Voltage Lock Out. The load turns itself off if the
voltage is less than a certain amount.
BTW, this doesn't help the OP's problem with incandescent lamps, but it
can be quite useful if the load is something like a buck converter. For
your 10V example, the buck converter input current will increase as the
input voltage decreases. When it gets below the UVLO threshold (say at
7V) the current drops to zero.
I seem to work with a lot of systems that have intermedate bus voltages
that come from a DC/DC converter with loads are also DC/DC converters.
Managing the inrush so everything comes up cleanly without hiccups
requires some attention to detail, but isn't too hard to get right.
Regards,
Allan
<[email protected]>
loads inside.
load.
certain designs.
Topology? The rest of this makes no sense without knowing the
topology.
This doesn't make sense. At low voltage it *is* taking a lot of
current. That's how we got here.
Constant current takes care of this.
Allan Herriman
On 05 Feb 2013 21:39:04 GMT, Allan Herriman
<[email protected]>
<[email protected]>
in message Some switchers current limit and some "burp", namely shut down
impedance -
loads inside.
the same. That's boring, and dangerous besides.
does.
voltages the duty cycle will be low. This means the synchronous
rectifier fet is carrying a much larger RMS current than it normally
would at full load.
certain designs.
putting you right in that box.
Topology? The rest of this makes no sense without knowing the topology.
You snipped some text containing the word "buck". It's a buck converter.
Alone, yes, a constant current limit will protect the bottom FET. But
with the other conditions that you snipped (so as to misrepresent my
argument) a constant current limit may result in the bottom FET
dissipating many times its normal power when the output is shorted to
ground.
I'm fairly sure you understand the concept.
Allan
<[email protected]>
<[email protected]>
impedance -
loads inside.
does.
would at full load.
certain designs.
People get pissed if one doesn't snip and they get pissed if you do.
Ah, well...
OK, but this makes even less sense.
ground.
I wasn't intentionally misrepresenting your argument. I'm trying to
snip out the irrelevant issues. You type a lot. ;-)
What other conditions. I'm still not seeing it.
I think I do but I don't see your point.
josephkk
design.
Allan
Hadn't met you before, didn't know you are a full member of the club.
Allan Herriman
On 06 Feb 2013 13:59:54 GMT, Allan Herriman
<[email protected]>
<[email protected]>
<[email protected]>
second maybe. The latter don't pull up loads very well.
when driving electronic loads that have switchers - negative
impedance -
loads inside.
does.
voltage is low can save money on thermal management for the lower
fet in certain designs.
Vout/ Vin is close to 1). This in turn means that the bottom FET can
be quite small compared to the top FET.
topology.
Ah, well...
ground.
The other conditions that you ask about were ones you described as
irrelevant and snipped.
Would a contrived example help?
Buck DC/DC converter.
10V input.
8V ouput.
10A current limit.
10mohm FETs
Ignore switching losses.
Assume the inductance ie large and delta-I is small.
Under normal conditions, the duty cycle will be approx. 80%. The top FET
is on 80% of the time and the bottom FET is on 20% of the time.
At full load (10A output current), the top FET dissipates 0.8W and the
bottom FET dissipates 0.2W.
(Now we design the heatsinking to handle 0.8W for the top FET and 0.2W
for the bottom FET.)
Now short the output to ground. The output current is still 10A, but now
the duty cycle is close to 0%, i.e. the top FET is almost never on, and
the bottom FET is on almost all the time.
The top FET disspates very little power, and the bottom FET now
dissipates 1.0W.
So, with no change in output current, the power dissipated by the bottom
FET increased by a factor of 5 when the output was shorted.
You could waste money by putting in a bigger heatsink to handle this
case, or you could do something smart like make the controller hiccup or
you could add foldback current limit.
I don't advocate the use of foldback current limit for most DC/DC
converters, but you can see that in special cases like this one (with a
high Vout/Vin ratio) that it can potentially make the design cheaper.
Regards,
Allan
