I run the 4060B with recommended voltage of 3v. I want to know how to output the same voltage (3v) coming into the 4060B (vdd) Q4-Q4 output pins.
I have options to increase the voltage from 3v, 4v and 6v. So if I increase the voltage going into the 4060B, say 4v, I want the same voltage coming out from the output pins Q4-Q14 to be 4v. Same with 6v coming in, and 6v coming out. Any ideas?
As far as I see in the datasheet, when the pulses are HI, voltages come out at around 1v. If the outputs are LO, voltage is lower than 1v. I want to output the voltages at 3v, 4v, or 6v if I choose to.
