I have built a simple boost switch mode supply. It runs off 6 volts and uses a Darlington arrangement for switching the inductor. I'm not sure what the value of the inductor is, it's a ferrite coil with several hundred turns of wire. I'm only getting about 24 volts output and trying to increase this. The output of a boost converter should be Vo = Vi(1/(1-D) where D is the duty cycle. I got better results when using a MOSFET, so I'm wondering is the limiting factor whether the transistor is being driven sufficiently into saturation. The duty cycle is about 0.9. Ltspice and the oscilloscope traces show the collector voltage is dropping to about 1 volt when the transistor turns on.
