I
Ian Jackson
- Jan 1, 1970
- 0
Presumably 75.25MHz is an analogue signal? In the UK, at least while theMichael A. said:It shows that you have a 6 dB slope, and the high end is 1 dBmv below
the standard level. It also shows a lot of errors in the recovered
data. QAM is the digital TV signal. Unscrambled channels are referred
to as Clear QAM
cable system has carried a mixture of analogues and digitals, the
digitals have been run 10dB below the analogues. If 75.25MHz had been
digital, it would be set at -5dBmV, so there would be a rising slope of
4dB, LF to HF.
In any case, if the 513MHz digital is -1dBmV, and other HF signals are
similar, that is more than sufficient for a digital set-top box. I would
think it should work reliably down to around -15dBmV. If I'm right,
whatever the problem is, it isn't being caused by a lack of signal
level.
