Increasing Current
Electro132
Feb 12, 2013
261
I'm needing help in increasing current from a 1.5 V batt by placing down 3x 100 ohm resistors in parallel circuit with an output. However, i have encountered a problem and found that the resistors (even though they each have their own line) tend to give out about 0.3 A of current each but this is also the same amount for the total output. It is supposed to be 0.9 A but i am getting 1.4 - 1.5 A total current output meaning something is wrong.
Can anyone help?
Martaine2005
May 12, 2015
5,318
Hi Electro, that is very confusing to me too.
If the battery is 1.5v and the resistors are 100Ω.
1.5 / 100 = 0.015. How are you getting 0.3A?
And adding all three resistors is 0.045. How are you getting 1.5A?
EDIT: How are you measuring this? What settings on the meter?
Martin
Arouse1973
Adam
Dec 18, 2013
5,178
Can you show us how you have it connected and are they defiantly 100 Ohm resistors. 1.5 Amps would mean the resistor combination was equalled 1 Ohm. What do you mean it's supposed to be 0.9 Amps?
Adam
14,487
Can anyone help?
Any added resistance is going to DECREASE the current from the battery(s)
There is no way to increase the current above what it is able to supply
show and tell us EXACTLY what you are trying to achieve
Electro132
Feb 12, 2013
261
Martin
I am using a multimeter to measure it. The red probe is in the 10A slot, the black probe in the COM and the switch is placed on 10 A current.
Electro132
Feb 12, 2013
261
Adam
Sorry my fault Adam, i didn't break the circuit and inserted the black and red probes so the current couldn't be read through the multimeter.
Electro132
Feb 12, 2013
261
That is not true. Each separate individual line is constantly flowing the same electricity through it therefore it is quite possible to achieve an increase in current by placing each separate individual line in parallel, having the total through a single output. At least that is the idea.
I am trying to achieve learning how to increase current using multiple separate lines which add up to the total output coming through the other end.
14,487
you need to restudy Ohms law.
Electro132
Feb 12, 2013
261
Its ok, i've found what i was looking for. Btw, thanks for the study tip Davenn, i don't mind reading up on it some more. :)
This thread can be closed now.
