Increasing speed of Opamp used as Comparator
John Larkin
Any particular standouts?
Regards,
James Arthur
DS90C402/SO8. Powered from +6 or so, puts about 4.5 volts into 50 ohms
in 640 ps. Don't tell anybody.
John
Michael A. Terrell
John said:
Klaus said:
Klaus Kragelund skrev:
[email protected] skrev:
Klaus Kragelund wrote:
John Larkin skrev:
On 11 Jul 2006 07:12:37 -0700, "Klaus Kragelund"
Hi
I have an application where I have a quad LM324 opamp and I'm using
only three of the opamps in the package. I would like to use the last
opamp as a comparator.
For simplicity the opamp is supplied from 5V and the value I compare to
is 2.5V. The input is fed directly to the other input. My problem is
though that the opamp saturates against either rail and is slow when it
needs to change the output state. (input stage i saturated due to V+/v-
is not operating closed loop
Are there a fancy way to actively clamp the output just below either
rail to speed up the "out of saturation" time?
Regards
Klaus
Be aware that, in many LM324's, driving one amp to its rails will do
very strange things to the other three amps in the package. So a
feedback-type clamp is necessary even if speed isn't an issue. So you
may as well use some other amp, or better yet a separate comparator.
The datasheet for 5 different manufactors I looked up didn't mention
this and I have never heard of this. Is this some soft of undocumented
feature that is constrained to us westerneers so the terrorist bombs
explode prematurely due to the quirks of the LM324s? (bad joke, sorry)
Look at the Linear Technology data sheets for the LT1006. and for the
LT1013 dual and LM1014 quad versions of the same amplifier at
http://www.linear.com/
The LT1006 is much better behaved than the LM324 (and much more
expensive) so the data sheets include a small gloat - see sheet 9 in
both data sheets.
They also give some information about the performance of the parts as
comparators.
Pity John Fields won't read this - the creep is claiming that I post
"Basically nothing but opinions formed long ago and 'You're not doing
it the way I would, so you must be wrong '"
I have tried the idea by Jon:
www.microdesign.dk/tmp/LM324Simulation_Sch.pdf
www.microdesign.dk/tmp/LM324Simulation_Plt.pdf
LM324 with no tricks, in saturation has about 15us of delay before
output reaches VCC/2
LM324 with the clamping trick has about 6us before VCC/2
LM324 with a BJT connected like this:
www.microdesign.dk/tmp/LM324_plusBJT.pdf
has 7us of delay until output shifts to VCC/2
The nice thing about the last one is that it is cheap and has logic
level output for use with microcontrollers and so on
Another circuit:
www.microdesign.dk/tmp/LM324_plusBJTClamp.pdf
This circuit has a response of 5us
Regards
Klaus
Another possibility is to go the other way: depending on what you're
doing, LM339 comparator sections can used as nasty, slow, horrible op
amps[1], and the left-over section makes a dandy comparator.
Or use the LM392, which combines an LM324 op-amp and LM339 comparator
in one package (any quads out there?)
Cheers,
James Arthur
[1] Not that an LM324 sets much of a standard[2].
[2] Though I'm still a fan of the nasty little beggars.
May you step on an LM324N, pins up, barefoot. [3]
John
[3] I have. Maybe that's why I dislike them so much.
I always seem to find 6502 chips that way. :(
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
K
Klaus Kragelund
Spehro Pefhany skrev:
I count 7 or so *additional* parts (over using an additional
comparator chip with pullup resistor), with a parts cost and power
consumption less than adding the cheapest IC comparator, but I agree
it looks a bit messy. It's not completely insane for huge volume.
Yes, correct.
I must admit I got carried away - had to follow through though.
If you look at the "BJT on the output" solution it is only 3 added
components and two of them are resistors (dirt cheap). And this
solution was the best I found with respect to the response time (5us)
Regards
Klaus
Jim Thompson
John said:
[snip]
John
I've only stepped on an LM324 once.
West Virginia sand hornets cured me of going barefoot outdoors.
The LM324 cured me of going barefoot indoors ;-)
...Jim Thompson
Michael A. Terrell
Jim Thompson
I don't have a lot of choice. I have to wear surgical support
stockings as much as possible, so I only wear shoes when i leave the
house. The stockings are bad enough, but adding shoes makes my feet hurt
and swell even more. Luckily I haven't stepped on any chip barefoot in
about 10 years, but I've pried enough 4164 DRAMs out of the soles of my
shoes over the years. :(
BTW, Email me when you have the time. I have an idea you might find
amusing.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
K
Ken Smith
Klaus Kragelund said:
The idea behind using the LM324 is that it is the cheapest I can dig up
(0.1USD) and we are running high volume.
I have the option to use the LM139 comparator - but will add an entire
new IC to the design (penalty = 0.1USD)
Maybe not, how nasty can the three amplifiers be?
The LM339 can be made to work as a very bad op-amp by placing a capacitor
on the output.
Also, you may be able to just have the LM339s oscillating away and doing a
ugly sort of PWM.
<need-to-know info snipped>
Thanks.
John
Your secret's safe with me ... and Google -- I think they're
steadfast, but I'm not as sure.
Cheers,
James
Cheers,
James Arthur
John
Gee, you pique-o-second guys... I stepped on a fast DIP-28 SRAM,
once, maybe twice--clenched its pins in my heel--and I still like
SRAMs. A lot.
Grins,
James Arthur
Robert Latest
On Wed, 12 Jul 2006 10:56:45 -0700,
John
Aah, childhood memories. It's amazing how much pain a DIL package can
inflict.
robert
John Larkin
John
inflict.
There's a term for people who deliberately step on IC's barefoot:
they're called pin sluts.
John
F
Fred Bloggs
John said:
Or how about using current-steering diodes into an opamp that stays
linear? That's more like 4 additional parts.
Is that the best you can think of, woman? LOL
John Larkin
You apparently consider "woman" to be an insult. That sort of attitude
must surely complicate your love life, if any.
John
Jim Thompson
John
Fred HAS a love life ?:) Bwahahahahahaha!
...Jim Thompson
F
Fred Bloggs
John
Is that the best you can do, Mary?
F
Fred Bloggs
...Jim Thompson
I'm not into the monogamy thing- I am a poly-something...
Michael A. Terrell
Polyunsaturated.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
