Inductor in LC filter
Aan
Sep 21, 2004
157
What type of inductors typically used in LC filter, is it toroidal or solenoid ?
Thanks.
AN920
May 15, 2005
359
There's LC filters of all kinds, low/high frequency and of various power levels. For example, you won't use toroid at very high frequencies because of the losses. Each applicarion will require its own selection.
indulis
Nov 21, 2005
488
The amount of current and frequency has a lot to do with selecting the proper core shape (for cross sectional area) and material (for Bsat). How much ripple current can yo live with?
You can get toriods in soft ferrite material now and the "Cool-Mu" toriods from Magnetics work very well in SMPS.
AN920
May 15, 2005
359
Maybe we should define "very high frequency"
Aan
Sep 21, 2004
157
I recommend a search on google for the type of filter you need.....
I have searched google and have not yet find any good site to use as reference to build LC filter..
I build a DC-AC converter with class D amplifier with frequency carrier of 10kHz.
0.1mAmp..how much ripple current typically find in any design of LC filter ?
audioguru2
Apr 6, 2004
12,026
The 10kHz noise will drive you nuts. Use a carrier frequency above 20kHz so it won't be heard.
prateeksikka
Jun 19, 2004
736
i dont think frequency is the criteria .
it is just the question of current carrying capability.
indulis
Nov 21, 2005
488
Frequency does matter.
In a power application for example... take a simple buck converter, Vout/Vin will tell you the ~ duty cycle, but the frequency will determine the "off time" (flywheel period during which current is flowing out of the inductor) of the converter. That "off time" plays a role in the inductor value and will determine the ripple current amplitude. A properly sized "power inductor" that works at 100KHz will not work at 1KHz... it will saturate. Frequency will determine max flux excursion and hence, max current capability.
