Input coupling for fixed resistor bias CE transitor amplifier ???
I am studying transistor amplifiers, specifically for the moment
Common Emitter with fixed resistor bias. For example Vcc = 15V, Rb =
200K, RC = 1K, Beta = 100 , capacitor coupled input connected to an AC
signal +/- 0.5V for example.
I think that I understand the load line characteristic curve stuff.
Ic will be centered at 7.15 ma and Vce will be centered around
7.85V . I believe that Vbe will fluctuate between .65V and .75V and
Ib will fluctuate above and below 71.5 uA by some value ?? . I guess
this could be determined by plotting a diode curve.
My problem is with the capacitive input coupling and the current flow
and how Vbe changes from .65V through .75V as the book seems to
indicate. Every book and source that I have kind of waves their hands
and says that the capacitor removes the DC bias and allows AC to
flow. The way that I think is to draw many pictures of the same
circuit and think of instances of time with concrete values for the
voltages, currents, direction of currents all over the circuit.
I can see how a capacitor would allow current to flow back and forth
in a circuit containing a capacitor connected in series with a
resistor. I know that current does not cross the dielectric. But
what if you throw a diode (transistor BE) in series with a resistor
and a capacitor. I don't see how this would allow current to flow
back and forth. I guess I need someone to break it way down so that I
can understand it.
Any help would be greatly appreciated. Thanks.
Phil Allison
back and forth.
** It won't, unless the diode is forward biased with DC current like it is
in your circuit - then a small AC current ( modulating the bias current
level ) can flow without causing the diode to stop conducting.
Another tip: think of a coupling cap as a battery with fixed DC voltage
that simply moves an AC voltages from one place to another where different
DC levels exist.
...... Phil
<[email protected]>
DC levels exist.
.....   Phil
I never realized that a forward biased diode could pass current in
both directions. Which brings up additional questions:
I have always believed that current can flow in only one direction at
a time in a section of wire. We can think of multiple currents
flowing down a section of wire in different directions like when
applying the superposition theorem but there is only "one" current
flowing in "one" direction which would be the algebraic sum of the
individual currents. Is this way of thinking correct?
If this is true, then how can current flow backwards through the
forward biased diode?
Phil Allison
DC levels exist.
both directions.
** You still don't - cos it cannot.
** Correct.
** At any instant in time, the current flow has one value and one
direction.
** You need to go look up the word " modulation" in a dictionary.
The current flowing in that base-emitter diode never changes direction -
it only changes amplitude.
There is an average DC value plus a smaller AC value superimposed -
MODULATING the DC value at any instant in time.
Think of a lake full of water - with waves on the surface.
It is THAT simple.
...... Phil
<[email protected]>
 "Phil Allison" >
both directions.
**  Correct.
direction.
It is THAT  simple.
.....   Phil- Hide quoted text -
- Show quoted text -
Ok, so the current through BE always flows in the same direction but
fluctuates above and below the 71.5 uA . I believe that the BE
current is at its maximum when the input is in the positive cycle and
at its minimum when the input is in its negative cycle.
To help me figure some stuff out, I have been thinking of the input as
a battery and reversing it back and forth to simulate the AC and
looking at how the capacitor would charge and discharge. Suppose that
the input battery is connected so that the negative terminal is
connected to ground. The capacitor should charge up with the side
connected to the base of the transistor more negative than the other
side. The current through BE should have momentarily increased.
Now switch the polarity of the battery around. The polarity of the
capacitor should eventualy switch also. The current from the negative
side of the battery should flow to the non-base side of the
capacitor. Also the negative charge on the base side of the capacitor
needs to go somewhere. Where do these electrons go to? Do they go
move against the BE current flow?
