Inverted colors after an (almost) successful iPod Touch repair
passerby
Anyone here with iPod repair experience?
Taking this thing (iPod Touch, 2nd version) apart was a separate long story
but it turned out that putting it back together is yet another challenge.
Needed to replace a faulty battery. For that the glass touch screen, the LCD
and the metal bracket had to come off. The darn thing had all parts glued
together with thin layer of what looks like non-drying silicon goo. Mr. Jobs
*REALLY* didn't want me to repair his products, I gather. As if I needed
another reminder never to buy Apple devices... But I digress.
Took some gentle prying of the parts apart and praying that LCD won't crack
while I was doing that. So, I soldered the new battery, put all parts back in
the reverse order and - bingo! Everything came back to life except for one
thing: the colors on the display are now inverted. What gives? The LCD module
seems to be a self-contained digital display with serial communication through
its connector (way too few contacts for anything else) - so if I put it back
wrong or if it's a bad connection, you would think the whole display won't
work. Needless to say, I re-connected the ribbon cable several times to no
avail.
Does anyone have and idea of what hardware issue associated with
disconnecting/reconnecting the LCD module can lead to inverted colors?
+--------------[ SERVER SIGNATURE ]--------
| posted via http://www.electrondepot.com
| Web, RSS and Social Media Interface to
| sci.electronics.repair and other groups
N
N_Cook
LCD
Jobs
back in
module
through
back
avail.
Could there have been a settings change to a hard-of-seeing option ?
Leif Neland
passerby udtrykte præcist:
Could it be a reversed polarizing filter in front of the screen? Or
perhaps I am totally confusing technologies...
Leif
passerby
responding to
http://www.electrondepot.com/repair...almost-successful-ipod-touch-repa-147623-.htm
Leif
Thank you for your replies, guys! I did think about a polarized filter of
sorts because it does in fact look like a polarized filter got reversed! But
there's only one orientation of the glass that it can possibly go back to and
the mylar backing (never heard of polarized backing, but who knows) stayed on
the LCD all the time, 'cause it was glued. In other words, if anything is
polarized, it went right back to the original orientation, so should not have
caused any issue.
I looked around for a different color scheme (better visibility option) - but
could not locate any. Sorry, not a big iPod user - it's my son's device. If
there's such a software option that can reverse colors, please advise.
Paul Drahn
responding to
But
to and
stayed on
have
caused any issue.
- but
What exactly do you mean by "reversed colors"? You need a color pallet
for the device to know how the colors relate. Problem could be just a
single connection to the display that is not making contact.
Paul
passerby
responding to
color pallet
"Inverted" was the best I could describe it. For example, when the iPod
starts, there should be a white apple on black background. It's now black
apple on white. I can kind of sort of see the menus but they look washed out
(although black text is still black, which is weird). Sometimes it might look
like one of the colors (most likely green) is missing, but then on some
screens you would see a bit of green anyway (for example, the battery icon is
green or yellow green anyway). All the icons are in wrong/odd colors
If this was a VGA display and it was behaving like that, I would have thought
a single connection is missing, too. V and H are fine - all shapes are
correct, I definitely see blue and red. Green looks weird or missing, so I
would go search for a problem with the G connection. But this is a digital LCD
display, I don't believe it's controlled by the same principal. So, if the
connector was off, the whole thing would probably be dark or at least look
seriously messed up.
