ahmed hassan
- Sep 13, 2009
- 13
- Joined
- Sep 13, 2009
- Messages
- 13
i have one question related to my circuit that i attached...
>>here some details about the circuit:
This is AC circuit mini inverter 10W - 30W. It Converts 12VDC to 220VAC Output 10W to 30W . Use easy Circuit Square Wave Oscillator Generator 50Hz. So Boost up Current High by D313 or H1061 or TIP41, Drive Transformer output 220V 50HZ From Voltage Supply 12V 1A - 2A.
my friend already succeed developed the circuit by using 12V/240V 0.5A transformer. the question is:
1. if want the output current higher than 0.5A (let say 1A), do i need to change the transformer rating from 0.5A to 1A?
2. the details of the circuit say that input voltage and current is 12V and 1-2A, but they are using 0.5A of fuse...i seem not understand how this happen because what i know the fuse is going to blow immediately by the effect of over the fuse rating .. or i misunderstood here?
thanks...
thanks...
