Inverter Circuit 12V DC to 230VAC Sine Wave
harrychoo
Sep 19, 2005
30
Hi all,
Any1 have idea where can i get the inverter circuit from 12V DC Sealed Lead Acid battery to 230VAC with pure sine wave output? The output power preferable to be around 400W.
Thanks.
alabimusty
Sep 8, 2004
34
You have the circuit already made, you can check on projects (500w inverter by Mustufa Younus).
Have a nice day!!
audioguru2
Apr 6, 2004
12,026
Hi Musty,
That project has corrections to make it work properly, and its output is a simple square-wave, not a complicated and expensive-to-make sine wave.
harrychoo
Sep 19, 2005
30
I have that circuits. What corrections have to be made?
So anyone have the circuits to make pure sine wave. Is it possible to make it and what is the idea do u all think to make it?
Thanks all for the reply.
audioguru2
Apr 6, 2004
12,026
The project of the 500W square wave inverter is here: http://www.electronics-lab.com/projects/power/033/index.html and is updated with a circuit that works.
You could make a pure sine wave inverter with a high current linear amplifier driving a transformer and waste a lot of battery power as heat, or you could make a complicated pulse-width-modulation (class-D) circuit drive a transformer with variable width pulses and waste less power. I have never seen a circuit because a pure sine wave is rarely needed.
harrychoo
Sep 19, 2005
30
Do u have any expalantion on how that 500W inverter circuit works? It quite complicated for me to analyze it.
How about modified sine-wave? Do u have any circuit about it?
Thanks a lot
audioguru2
Apr 6, 2004
12,026
Hi Harry,
The modified 500W inverter is simply a CD4047 Cmos oscillator/divider/opposing outputs IC driving LM358 dual opamp buffers to increase its output currents. Each buffer drives sets of transistors connected in a darlington arrangement and the output transistors are paralleled for very high current. The transistors apply their high current swings to a center-tapped transformer that steps-up the voltage.
I haven't seen the schematic for a modified sine wave inverter. I heard that their output is a square wave with a step in it. I don't know how they make the step without overheating.
Maybe the transformer has a tap on its low-voltage winding and a separate output transistor drives the tap on each side to make the step.
Actually, a separate transistor would drive the full winding to make the step, and another transistor would drive the tap for full output on each side. ;D
alabimusty
Sep 8, 2004
34
Hi Audioguru,
I have tried this circuit before, although on a breadboard but I couldnt get the right output, perhaps from my step-up transformer windings. Information regarding this shall be appreciated.
Musty
audioguru2
Apr 6, 2004
12,026
alabimusty said:
I have tried this circuit before, although on a breadboard but I couldnt get the right output.
You can't feed 50A from the car battery through the resistance of the wiring and contacts of a breadboard. Look at the size of the wires on booster cables. They can carry 50A.
audioguru2
Apr 6, 2004
12,026
Alun said:
You might be alright if you tested it off load.
Good point, Alun! ;D
But not if it had a transformer from a microwave oven that wastes a few hundred Watts because it doesn't have enough turns, therefore its inductance is too low.
alabimusty
Sep 8, 2004
34
Hi audioguru,
You are right, but what I did was to use a hard core copper with battery terminal connected to a special power feed to the breadboard.
Musty
audioguru2
Apr 6, 2004
12,026
What was wrong with its output? ???
You can't load it when using the flimsy wiring and contacts of a breadboard.
ante1
Jan 24, 2004
4,138
Hi Harry,
This is a “modified sinus” inverter, as you can see it is much more complex than the square wave inverter. This one is more powerful but even at the same power level it will still be more complex to construct and build.  ;)
audioguru2
Apr 6, 2004
12,026
Hi Ante,
I was looking and looking at that 3kVA schematic and wondering, "how do dey do dat?" and looking for a way it can make a "stepped" sine wave. Then I realised that it simply pauses between its pulses like this:
ante1
Jan 24, 2004
4,138
Hi Audioguru,
Yes, this is closer to the sine wave than the square wave but not perfect though. I am sure that some equipment will be more forgiving to this waveform than to square wave. But obviously the circuit becomes more complex which is hereby proven by the fact that you had to look twice to see how it works! ;D ;D
audioguru2
Apr 6, 2004
12,026
Hi Ante,
Since it pauses for half the time, then its transistor current must be double the amount of current in a square wave inverter. :eek:
I wonder why it uses expensive P-channel Mosfets instead of better, cheaper N-channel. ???
ante1
Jan 24, 2004
4,138
Hi Audioguru,
The 16 MOSFETS  should be well spread out over a BIG heatsink. I don’t know if there are any big differences in price between N and P channel Mosfets, or maybe this guy had them in his junkbox anyway. ;D
audioguru2
Apr 6, 2004
12,026
Hi Ante,
There are many more N-channel Mosfets than P-channel. The N-channel ones have a much lower Rds and cost less than P-channel.
