Inverter Circuit 12V DC to 230VAC Sine Wave
audioguru2
Apr 6, 2004
12,026
steven said:
i just want these bd234 trannys but if the tip142 is ok ill try it ,even though they are bigger
No. The huge TIP142 is completely different. It is an NPN darlington transistor. A TIP32 is a PNP single transistor, is not too big and will replace the BD234.
i rplaced the tesla trannys for 2n3058 trannys which i was told are more poerfull than the 2n3o55, but the voltage went down and the same left tranny got hot.
No. The 2N3058 is a small PNP transistor, not an NPN power transistor like the 2N3055. You need a power transistor with high current gain, not high power. Then the project will produce more power.
steven2
Jan 19, 2004
1,698
:)oops 2n5038 tranny was the one i used in place of the  tesla trannys i  got the part number wrong. the 2n5038 i have is the same size and shape as the 2n3055 npn tranny, thats twice i oops up.
audioguru2
Apr 6, 2004
12,026
Hi Steven,
You wrote that the microwave lightbulb is marked 2A at 250V. That is 500W!
The lightbulb would cook the food and the microwaves aren't needed.
Look again, it is probably marked, "0.2A". Then it would be 50W at 250V or 40W at your 240V.
ante1
Jan 24, 2004
4,138
Hi Steven,
The 2A 250V you’ve got there must be the maximum rating for the socket not the bulb I believe.
ante1
Jan 24, 2004
4,138
These bulbs are usually something like 10 – 20 W, this is not always marked on  unfortunately.
steven2
Jan 19, 2004
1,698
i found the details it was on the shiney metal side of the globe it was a bit hard to see so i used my dome lense to view it , and i took a picture of it useing the zoom lense of my digital camera. its 240 volts 25 watts so how many amps is it , my inverter circuit only makes it look dim as i have it turned down  so the tranny wont over heat
steven2
Jan 19, 2004
1,698
:)i have to make the rectifier circuit to run off this inverter so i can use it in my hydrogen/oxygen from water  exsperiment heres a picture of it under construction
audioguru2
Apr 6, 2004
12,026
The current in the light bulb when it is very bright is only 25W/240V= 0.1A. Since yours is dim then its operating power and current are a lot less.
Maybe you can fix the cause of the hot transistor:
1) Swap the Tesla output transistors.
2) Swap the BD234 driver transistors.
3) Swap the 15 ohm output base drive resistors.
If the other side gets hot then you have found the problem.
steven2
Jan 19, 2004
1,698
:)thats only a small one sp it may be easyer to work and i can add another  t peace in the middle section  and use that and the left or right section , this will be like bringing the electrodes closer for faster effects
AN920
May 15, 2005
359
A square wave inverter can provide a reasonable sine wave output with a few modifications. This was a common method long ago before fast switching pwm. This was implemented with scr type square wave inverters but can also be applied to transistor or fet types. Basically the switching current is forced to be resonant producing a sine output. This was good up to several kW's.
The drawback is that the tuning element values are somewhat load dependant. Also voltage regulation is also load dependant. A more complicated sceme can be used which requires a extra tap on each half secondary winding to provide passive feedback to overcome these problems. Performance was typical 2.5% output change for 25% input variation at full load.
Pictures show typical waves to be expected from this inverter. One is from my simulation and other from actual documented test.
shivamukiri
May 14, 2010
hai guys this is shiva newly added as ur friend please i want pure sinewave inverter circuit diagram for input 24v dc output 230v ac with pwm based circuit diagram pls send as early as possible.the rating of inverter is 1kv or 2kv simple circuit,
thanking u
K
Kasamiko
It's been awhile since my last visit on this thread and was so disappointed that almost all the attachment is NOT available anymore.
404 - Attachment Not Found
Or it's just me?  ???
Good day to all..
Rhonn
Hero999
Oct 28, 2007
2,433
Many old attachments were lost when the server crashed awhile ago.
