Hello I am going to build the IR Remote Control tester found on the Projects section of this website and I see that in the schematic, you can put a Volt Meter to read the power of the IR. I would like to modify it so that instead of a volt meter, I put 6 leds (2 green, 2 yellow and 2 red) and the more power the ir send the more leds will light up starting from green to red.
In other words I would like to add an LED volt meter to it. And since I will be using it with a battery, I would like to make a small slide switch to it so I can either read the strenght of the IR remote or read the bettery life!
Thanks a lot
Thanks a lot
