Is cycling a switching power supply on/off a problem
JacobT
Feb 27, 2013
3
Hi guys
I'm trying to piece together a temperature controlled system using a PID and a TEC.
Now my original idea was to use one switching power supply to power the PID and the same to power the TEC, and control power to the TEC via a SSR (which in turn is controlled by the PID).
However, the SSR I have is for AC output, so it will not work with the 12V DC i'm getting from the power supply.
An alternative is to use a separate power supply for the PID and then have the SSR cycle the 12V switching power supply on/off as needed.
The question is, will the expected fairly rapid on/off cycling potentially damage the switching power supply?
Hope that makes sense... I'm quite the novice..
thanks
Jacob
pwdixon
Oct 14, 2012
52
Just use a mosfet to switch the TEC current and let the power supply be on all the time. It'll be way cheaper than the SSR in any case.
JacobT
Feb 27, 2013
3
Thanks for the quick reply. I've gotten a mosfet and that does seem to be a better solution.. only I have a small "secondary" problem. The PID I have seems to have the positive "terminal" constantly hot and then "switch" ground (hope that makes sense) the problem is that I have a constant +10V from the positive terminal, so the mosfet is constantly "on".
Any easy way to fix this?
Thanks, I hope my mumbo jumbo makes sense :rolleyes:
-Jacob
14,317
You probably have an NMOS FET.
Use a PMOS FET
pwdixon
Oct 14, 2012
52
Are you trying to switch the high voltage side or the low voltage side?
If you have an N channel FET you could switch the low voltage side but you might want to invert your drive signal if On and Off are interchanged.
JacobT
Feb 27, 2013
3
Use a PMOS FET
Hmm Thanks, I'll look into this, does it work like the NMOS only I connect the positive rail to the source? and then connect my "negative/ground" terminal on the PID to the Gate?
Thanks again.
-Jacob
pwdixon
Oct 14, 2012
52
Thanks again.
-Jacob
Can you draw a picture I can't tell what you circuit looks like.
