is it possible? 1600W step-down transformer so tiny!
Travis Jordan
frischmoutt said:
That's the normal way to post on most company e-mailers (id; Lotus
Notes). I keep this habit;
Then please post further comments on your company e-mail system, not on
this Usenet newsgroup.
John Fields
Stop being rude, and learn how to write "anyway" in your first and
only language, which turns out to be my third one.
I wasn't being rude, I was being insulting, and English is neither
my first nor my only language, so it turns out that it's _you_ who's
being pretentious, as well as presumptuous.
Learn also to put
the commas inside the quotation marks, and to leave a space between
the numerical value and unit symbol
(http://physics.nist.gov/cuu/Units/checklist.html #15).
The commas aren't being quoted, they're being used to separate the
quotes, so in this case they belong on the outside of the quotes.
Depending on context and how I feel, sometimes I prefer to abut the
symbol to the value, and since neither you nor anyone else seems to
have any problem deciphering my meaning, I'll continue to do it that
way, thank you very much.
If you can't
use your own language, don't be so pretentious.
Hmmm... I think we covered both of those subjects earlier.
Of course I can multiply, and what I do is none of your business.
Well, of course you can multiply, but it seems you have trouble with
what the products mean. That is, since one of the posters wrote
that he had a 12.5kW cooker which was connected to 240V 60A mains,
it should have been obvious that, since:
P = IE
Where P is power in watts,
I is current in amperes, and
E is voltage in volts, RMS
The mains could supply:
P = IE = 60A * 240V = 14.4kW.
Now, since he stated that his cooker used 12.5kW, it should have
been a simple matter of subtracting 12.5kW from 14.4kW to find that
the difference was 1900 watts, with the mains having that reserve.
Oh, you figured it out eventually, and then pouted about it with
this gem:
"Ok, I may end up believing that you have access to 60 A @ 240 V.
But I find it... surprising... that you guys use 12.5 kW cookers.
That's a hell of power. And ok, even if that was the case, I could
never call that "reasonable."
Like anybody gives a shit about what you consider reasonable.
Mochuelo
Stop pretending you know what you're talking about. You don't have a
clue. The commas go inside the quotation marks even if they are not
part of the original material (as is usually the case).
http://owl.english.purdue.edu/handouts/grammar/g_quote.html
Put commas and periods within closing quotation marks, except when a
parenthetical reference follows the quotation.
"He likes to talk about football," she said, "especially when the
Super Bowl is coming up."
In his poem "Mending Wall," Robert Frost questions the building of
barriers and walls:[...]
BTW, it's not: "a "fucking stupid"", its just: ""fucking stupid"",
Of course I can write "a fucking stupid." "Stupid" is also a noun, not
only an adjective. You should know this.
John Fields
clue.
Hmmm...
Where did I just read this?:
"This is my last reply to you, John Fields."
Seems we have a liar in our midst...
Christopher Tidy
Hi James,
As one person mentioned, if you badly want to use your pizza oven, buy
a genuine transformer with plenty of copper and iron in it. It's the
proper solution to the problem, will produce a nice waveform and won't
run the risk of overheating if you select one with an appropriate
continuous power rating. Such transformers are frequently used on
building sites in the UK. Usually they have a yellow fibre glass case,
but sometimes they're grey metal if intended for permanent
installation. I have one which I use to power a Hougen magnetic drill,
and they perhaps aren't as expensive as you might think. Figure about
£30 plus delivery for a used transformer in good condition. If you
search hard you might get one for less. Something like this should
satisfy your needs:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=7604254309
Best wishes,
Chris
