DeanB
- Jan 1, 1970
- 0
Because I have 900 of them on my tree and they are quite bright!
John said:That depends on how they are wired.
If a transformer is used, then you could use an adjustable transformer
(Variac) to reduce the voltage to the transformer.
If a transformer is not used, you could use a standard light dimmer -
check the combined wattage of your lights to get the proper capacity
dimmer.
Note that standard light dimmers will NOT work with transformer
powered lights (or not for very long...
John
Hobby, hobbier, hobbiest. ITYM hobbyist, but you may well be right, heIt would be trivial for an electronics hobbiest, but my guess is that
you are not one.
I'm not one to usually nitpick on that sort of thing, but the errorPete said:Hobby, hobbier, hobbiest. ITYM hobbyist, but you may well be right, he
doesn't seem to be the hobbiest of them all!
The light output from a light emitting diode is a function of the current
passing through it. Most devices will show a wide variation of brightness
from say 1 to 20 mA.
over "hobbyist" has always jumped out at me.
I suppose if I could figure out why it's a common error, I might
be more understanding. But I can't figure out why the mistake is
made, so it somehow seems worse.
DeanB said:I know they are 4V per bulb. If I take out one bulb, then all of them
go out so I assume they are in series and not in parallel. I can't see
any transformer.
Shouldn't have sent the correction, sorry. Thing is, it didn't annoy me,Sorry. It won't happen again. I am annoyed by that sort of thing, too. But
let's not turn this thread into "spelling errors that annoy me".
DeanB said:Because I have 900 of them on my tree and they are quite bright!
For what it's worth, I bought some LED Christmas lights (they certainlypetrus bitbyter" ([email protected]) said:Hmm... Nine hundred LEDs in series with 4V/LED will require 3.6kV. Unlikely.
How do you now they are LEDs anyway? If they are directly connected to the
mains - so no transformer or other black box in between - I assume them to
be incandescent bulbs.
Pete said:Shouldn't have sent the correction, sorry. Thing is, it didn't annoy
me, I just thought it was amusing and I was in a silly mood.
Note to self: Do NOT post while drunk... Do NOT post while drunk...
Michael Black said:For what it's worth, I bought some LED Christmas lights (they certainly
don't get warm) two years ago, and there's no transformer. I assume
they use some sort of series and parallel combination. Though I've
not wanted to sacrifice the string to figure out what's going on.
I suspect it's not a single string of 900 lights, but a number of separate
strings, coupled from one to the other in the same way that traditional
incandescent Christmas tree lights went, a plug at one end and an outlet
at the other to plug in the next string. That way you don't have to
bring each string down to the outlet, but each individual string is
seeing 120VAC.
Michael
JeffM said:Calculate the power consumed by your lights and,
being careful not to exceed the rating of the device, get one of these.
http://froogle.google.com/froogle?scoring=p&price=between&price1=1&q=tabletop-lamp-dimmer
Bob Engelhardt said:No no no. I was replying to Michael Black, who was annoyed. Your post
was clever and amusing itself and not offending (oh,no is that the right
word?). I would try drinking while posting, but I think that my posts
would become more error-filled rather than more clever.
Bob said:No no no. I was replying to Michael Black, who was annoyed. Your post
DeanB" ([email protected]) said:They are 60 bulbs on an individual string. I guess in the wire there
are 2 pairs of wires, giving 110 V over a set of 30 bulbs, or just
under 4V each in series, which is why they all go out (actually only
half of the string goes out).
I will try a dimmer (I have one like that) and give and update tonight.
Oooh, the tension is killing you all, I know! I'll be sure to post
before midnight, then you will be able to get some sleep without being
concerned![]()
Fair point but I assume there must be some form of current limiting in the
exisiting strings. Surely these are not just connected across the rectified
mains supply?
If the current is limited by a resistor then the brightness could be
controlled by increasing its value.
Bob in UK
