Is It Worth Repairing My Fridge or Should I Replace It?
LinaHahn
Feb 28, 2025
My 7.5-year-old Frigidaire refrigerator has started having cooling issues in the fridge section, while the freezer on top still works fine. Recently, I noticed that drinks inside the fridge aren’t as cold as they should be—water stays around 14°C (57°F), and some food has spoiled. The unit still makes noise, and I already tried turning it off for two hours and cleaning the coils, but that didn’t solve the problem. If I bring in a technician, the diagnosis alone will cost at least 150, and the total repair might be anywhere between 200 and 300. Meanwhile, a new refrigerator costs somewhere between 700 and $1,000. Given its age, would it make more sense to replace it, or should I invest in getting it repaired?
Martaine2005
May 12, 2015
5,318
I’m afraid that only you can make that decision.
It might pay to watch some YouTube videos on your symptoms. It could be as simple as a new thermostat to requiring a major tear down and re-gassing.
Most manufacturers have their own common faults which can be researched quite easily on the net.
Externet
Aug 24, 2009
944
Leave it unplugged for at least 24 hours with doors open (will need to put your perishables somewhere else.) There is ice build-up in the passage blocking air flow from top to bottom or ice build-up is stopping the internal fan blades or the $10 fan is dead. Do not call a genius, do not dump it. Can you hear the internal fan working ?
Sometimes the ice build-up (not defrosting long enough) is because the thermal sensor is not healthy, or the timer that cycles between cooling an defrosting times is faulty. But too early to tell. Just unplug it a looong time for now and come back with results.
Never put anything hot in a refrigerator; let it cool to ambient temperature first !
Martaine2005
May 12, 2015
5,318
And to quote myself “most manufacturers have their own common faults”.
Ice build up, generally blocks and causes water to be present in the lower tray or shelf.
But of course worth a try.
Depends on the type.
If frost free, above applies.
If cyclic defrost, then gas leak has occured and dump.
John R Retired
Mar 13, 2022
155
The freezer feeds cold air to the bottom section. There is a vent in the freezer connecting it to the section below. Make sure it's not blocked
My fridge was doing the same thing. I checked out youtube and found that there is a drain tube in the freezer, which drains water down to a pan on the floor. That tube gets filled up with ice occasionally and stops the fridge from cooling and freezing correctly. Then you have to unplug your refridgerator and put the food in some other cold unit and thaw out the clogged up drainage tube from the ice inside. I used a hair dryer and poured hot water down the tube. which after a while melted the ice inside and allowed water to drain to the pan below. After some research I found this was a design flaw by the engineers. I also discovered on youtube that there is a fix for this problem. You can buy a little attachment on Amazon which is a few inches long and attaches to the defrost heating elements in the freezer and the other end inserts into the tube which constantly melts any ice forming in the tube. You can also make one your self with a small piece of copper wire
wrap it around the heating element and stick the other end down the tube about 3 or 4 inches. I've tried the wire and the Amazon part.
The Amazon part works better and I have not had the same problem again.
Also some refridgerators have circuit boards that can be easily replaced to correct malfunctions if a drainage tube is not the problem but
it is something else. Be prepared to removescrews and panels that cover some fridge components , circuit boards etc. A socket ratchet
and variousscrew drivers worked fine for me. I put all myfood in several ice chests with ice which works great unless you have an extra refridgerator and freezer. You'll probably have to work behind the fridge also and remove some covers particularly near the bottom.
ariajames_121
Mar 17, 2025
5
It might be better to replace the fridge since it's already 7.5 years old, and repairs could cost a lot for a unit that's near the end of its lifespan. Newer models could be more energy-efficient and offer better features, plus you’d avoid the hassle of another breakdown. If the repair costs are close to a new fridge, it’s probably worth considering an upgrade.
73's de Edd
Aug 21, 2015
3,730
Mme Linnahahn
YOU NEGLECTED . . . a VERY important question, from my perspective.
WHAT IS THE MODEL NUMBER OF THAT FRIGIAIRE UNIT !
(From a person with . . . . . not a 7.5 year old . . . . . . . but a . . . . . . 69 year old Frigidaire . . . . . . still in daily use, as a backup/overflow/spare )!
(LIKEWISE . . . . . . . but, OHHHHHHHHHHH! . . . . . the extra electric billings that I have paid out, in that interim.
Externet
Aug 24, 2009
944
Diagnose, diagnose, diagnose. If you do not; will never know if it is 'worth' repairing for a little money.
If you replace; this thread did not serve its purpose. Wasted time on everyone. An 8 year old refrigerator can keep working over a dozen years more if not abused, properly operated.
If you do not give a sheet about leaving door open, putting hot things in it, cleaning its condenser, checking the fans work. Well yes, it is your money, go buy a new expensive one that will hurt your wallet.
If you open a thread and do now show up later; I do not care a bit for your troubles. Bye.
73's de Edd
Aug 21, 2015
3,730
If you open a thread and do now show up later; I do not care a (sheet) for your troubles. Bye.
Delta Prime
Jul 29, 2020
2,996
Your solutions by helping others has helped me more than twice… you’re a heavy hitter ,Like Don Lancaster, Joseph J. Carr . :)
