Isolated, regulated, toroidal step down transformer AC power supply design.
Two Bob
What a bloody HOOT !!!!!!!
Lets all keep this CRETIN on the fishing line as long as possible !!
What entertainment !!
You cruel bastard!!
Two Bob
I am not compelled to explain anything more than what I already have and
what I have explained is more than sufficient for my purpose.
YOU are the idiot asking for help here! If you cant give more info, I doubt
you will get more help.
James
Two Bob said:
You cruel bastard!!
But it's true
No only did the OP not say in the beginning what he's really trying to
acheive, but he is off on a completely wrong tangent arguing that he is
correct.
Theres more than one way to skin a cat, but the OP is trying to do it by
blindfolded shoving his fist fair up the cats arsehole and turning it inside
out and hopefully when he takes the blindfold off he'll relise it wasn't a
cat he had in the first place.
OK...well i guess thats a pretty fucked up comparison, but not far off the
Mark.
James
Phil Allison
"James"
"Two Bob"
But it's true
correct.
inside out and hopefully when he takes the blindfold off he'll relise it
wasn't a cat he had in the first place.
Mark.
** ROTFL
Nice one....
.......... Phil
Mark
The way I understand it, the regulation that already occurs within the
application can only operate within a tolerance of the regulating IC's
nominal input voltage. The application is using 15 Volt DC regulators
(output), after the bridge rectifier, and can only operate (+/- x%) of 15
volts DC input.
The rectification of (nominally) 9 VAC I understood to result in 18 VDC
(ignoring any small voltage drop across the diodes). So even when the input
voltage is nominal,
the input voltage to the regulating IC's is only within 20% of their nominal
output.
Now what happens if the domestic supply voltage is not nominal?
If the domestic supply comes in at 264 VAC (+10%), the existing linear
regulator now supplies 9.9 VAC to the application, the bridge rectifier
doubles that to 19.8 VAC. The input voltage to the regulating IC's is now
only within 40% of their nominal output!
I monitor the domestic supply and regularly see voltages coming into our
house outside the range of +/- 10%.
One solution, of course, would be to redesign the power supply within the
application's case, including upgrading the regulating IC's input voltage
tolerance to at least 40% of its output, if such an IC can be found!
However space within the applications case would not allow for a toroidal
transformer, which I consider to be the optimum solution for a number of
reasons that I don't need to explain here (or maybe they will insist that I
do that as well?!!), and I have already invested considerable effort (and a
small amount of money) in upgrading the capacitors within the existing
application's power supply and really don't want to loose out on the already
considerable improvements I have made therein.
Quite frankly, I am astounded and reviled that such a simple request has
generated such a vile reaction from this group. I can only assume that it is
because they, like me, were unable to Goggle a suitable design. So as to
maintain their allusion of expertise and so they hide their inability to
self-design a suitable solution, with insults!
I wonder what would happen if I took a simular request for such a simple
thing to another newsgroup, say 'us.electronics', and pointed out to them
that 'aus.electronics' does not have a single contributor who can satisfy
the request. I wonder what they would say. "Too difficult", do you think?
James
volts DC input.
**** Is that right? I would have thought it closer to 12.7v (minus the
forward drop of the diodes), and from one 12Vdc supply how are you going to
achieve +/- 15V. Of course you could use half wave rectification for
+/-12Vdc but if you want to achieve a very stable supply?????
voltage is nominal,
nominal output.
**** Nope....and an input 20% below the desired output wont work will it?
Assuming (because you wont tell) you are talking about 7815 / 7915
regulators or similar you'd want a good few volts above the output if you
want any sort of regulation.
Mark
So your presumption may be that asking for help at 'aus.electronics' is an
idiotic thing to do? Can't really disagree with you there.
I am all too aware of the inherent perils involved in asking for help on any
newsgroup inhabited by the likes of Phil and his 'Phil-o-philes'.
That reason alone is enough to make me cautious of providing any more
information than I need to. My perception of Phil is that the more
information you give him to analize (sic), the deeper your own exposure to
his vile hatred of (just about) everybody on the planet.
Mark
Well, according to the schematic it is +/- 15VDC after regulation. And I
believe it.
Yes, I believe it is half wave rectification. Something above +/- 15VDC,
after rectification of the 9VAC. The schematic does not say, probably it is
assumed knowledge.
I have already employed high ripple current Backgate capacitors after the
regulators, and in coupling the Op-amps, and at quite a few other points
throughout the power supply. Worked a treat in improving the sound.
Yes they are 7815 / 7915 regulators. I remember reading the spec for them
(not that I can find it now).
The case is simply stuffed full of large caps throughout the power supply
and analogue section, and it would simple break my hart to have to pull them
out and start over again (to eliminate the half wave rectification)
Which is why I made my objective the replacement of the 9VAC wall wart power
supply.
Too much to ask?
Two Bob
But it's true
correct.
Mark.
LOL
After reading the rest of the thread, all I can say is "Go for it Phil"!!
Poxy
A common 7815 regulator will put out a stable 15v for input voltages between
17.5v and 30v. That's plenty of headroom for any overvoltage situation on
the mains side.
Mark
I realise that my breath is wholly wasted on this Philistine, but:
A regulated circuit can benefit from the pre-regulation of the incoming AC.
Specifically, where the incoming AC strays outside the operating range of
the regulating IC's output voltage, the benefits may include, for example,
not having any blue smoke emanating from the unit.
Regulating IC's aren't expensive, so it seems a common sense precaution to
make, particularly where other work, (the replacement of the existing
wall-wart with a toroidal step down transformer) is envisaged. Which is
EXACTLY what I originally indicated.
Hey Philthy, we miss you over at 'aus.hifi'.
Mark
It certainly would be reassuring to know that I have more head room than I
remember.
Show me your spec please. I remember reading something less (much less), but
I haven't got it in front of me.
I am sure that you can appreciate that since I am replacing a wall-wart
power supply with a toroidal step down transformer, the cost of an
additional IC regulator is rather trivial when compared to the cost of the
rest of the project.
It may turn out that the particular IC's that I have in place don't regulate
to a 30 VDC input, either by design or circumstance.
The application certainly occasionally behaves erratically (on/off clipping
of output) and I know that this behaviour coincides with over voltage supply
problems. I monitor the domestic supply using software which queries and
records data from an UPS. So there is no doubt about the cause. 100%
correlation.
If the cost of certainty (solving the problem by putting in a bigger, better
IC regulator) is about 10 bucks (and, apparently, putting up with a few
arse-clowns because I was foolish enough to ask for help @
'aus.electronics') then I can go the extra distance, I guess.
Mark
What "tangent" would that be?
James said:
But it's true
correct.
Mark.
James
Mark
When people ask anything from me, they must display to me the same respect
that I gave to them, when I asked something from them, or I will not submit
to their demands.
If the cost of this personal policy is not receiving the help I requested
then I would much prefer not to receive it. The price of self-respect is
inestimable. Is that too difficult for you to understand?
The direct inference from your comments here and elsewhere on this thread is
that you expect me (and possibly all newcomers) to submit to this bulling in
order to receive the help that they need.
That is the definitive behaviour of a 'Phil-o-phile'.
You are a 'Phil-o-phile' and I expect nothing from you.
Mark
Personally, I think it's very amusing to be called an arrogant pig by one
who then goes on to immediately infer that the power to "get to decide what
others should accept or believe" is a right that; a) Exists. b) Could be
earned, granted or perhaps even shared with others, at the decreation of the
right-holder(s).
Cognizant with this position is the logical assertion that the entry fee to
this exclusive club of 'deciders', as you so called them, is the
demonstration of superior knowledge or experience.
Perhaps not coincidently, I suggest that this hypothesis serves as a
tentative STRUCTURAL description for the organisation of?
....'Phil-o-philes'.
Just for my future edification, can anyone offer me a list of possible
members of the 'club of deciders' at 'aus.electronics'. To the uninitiated
contributor at this newsgroup, this would be an invaluable aid to 'fitting
in'.
Know what I mean?
Alex Gibson
believe it.
is assumed knowledge.
them out and start over again (to eliminate the half wave rectification)
power supply.
Too much to ask?
Why ?
If it works don't fix it.
If you need dual rails, thats the usual way to do it.
Half wave rectifier from a centre tapped transformer + linear regs.
Nice and cheap.
Alex
Bob Parker
Ummm, can someone enlighten me as to what a Backgate capacitor
is...? I did the obligatory Google searching but didn't find anything
very informative.
rebel
Not exactly. There are precious few (if any) three-terminal regulators that
won't handle a 30V or 40V input for 15V out. Your configuration is far more
likely to suffer from UNDER-voltage out of the rectifier arrangement.
volts DC input.
No, three-terminal regs don't work that way. Get a datasheet for a 7815 or 7915
and have a good read of the input voltage range. Let's see, 7815 ...
Dropout voltage (typical): 2.0V
Vin (max): 35V
So a 7815 will regulate as long as the input voltage doesn't exceed 35V or drop
below 17V on the troughs of the input waveform.
It may be small but it isn't insignificant. And I don't like your rectification
theory either.
So even when the input voltage is nominal,
output.
The Vin-Vout capability of (again, 3-terminal) regs is a spec figure you'll find
on the data sheet, often termed drop-out voltage. See above. It's *not* a
percentage thing. If your input drops (even on transients) to 2V above your 15V
output, or less, you will lose regulation. 20% of 15V is 3V which - if your
rectifier is really providing 18V DC - is barely enough, and ripple at any sort
of load will kill you.
regulator
I think you mean transformer
I don't like your rectifier model, but let's ignore that for the moment.
They should be happier. Warmer, but happier. Realise also that the output of
your rectifier system will show significant ripple as load current increases,
and those dips threaten the very regulation those regulators are trying to
provide.
Your concept of how regulators work is more than a worry. And IMNSHO it
unperpins all your problems.
Read the data sheet, and understand what a 3-terminal reg does.
Throwing bulk cap around will obviously improve (aka mask) the regulation
situation. But it is masking the symptoms, not fixing the cause.
You mentioned in another post that this is accompanying a move from a 9VAC
wall-wart to a hopefully better transformer.
What I sincerely suggest you do is (in order):
(a) Get the data sheets for the regulators that you are using. If they aren't
7815/7915 then I feel compelled to ask why not.
(b) Measure (even with a DMM) the input voltage to the regulator(s) and
convince yourself that you have enough headroom to operate properly. Better
still if you check the ripple with a CRO too. Even better, get a CRO and watch
the waveform applied to the input of the regulators, and load/unload teh system
so that the ripple can be quantified.
(c) Check whether the regs are running hot to touch.
(d) Try a 12VAC wall wart, unless the DCin to the regs is already 23V or more.
Quite frankly, I am astounded that you seemed to think that these problems are
best solved by shooting for an (affordable) transformer offering 1% line
regulation. If that were the best solution, such transformers would abound, and
Google would have turned up a mutitude of solutions for you. Rather, the
solution to such requirements have been de rigeur for decades, earning the tag
classical.
Your request was further obfuscated - and the task of steering you towards a
sound and achievable/affordable solution - by giving more of your planned
solution than the description of the application and the problem.
No, they'd wonder why you were searching for an electronic sledgehammer.
Whether you choose to follow my, or anyone else's, suggestions is up to you.
But among the flaming, you have been given more than enough leads to achieve a
sensible outcome.
And please don't top-post
Alex Gibson
remember.
but I haven't got it in front of me.
Maybe if you bothered looking at the datasheets for the devices you are
using.
Usual first step before using a device is read the datasheet or manual.
For a 7815
http://www.fairchildsemi.com/pf/LM/LM7815.html
http://www.national.com/ds/LM/LM340.pdf
input range is 17.5V to 30V DC.
Need minimum of 17.5 to get regulated 15V output.
Using a simple AC circuit + bridge rectifier or diodes + linear reg is a lot
cheaper and simpler than mucking around with AC regulation.
May not be the most energy efficient circuit but is simple and easy to fault
find.
Also a less noise than any switchmode or boost/buck converter circuit.
Alex
Mark
In retrospect, it was a vague question that he begged me to ask of myself.
Maybe the 'value' he refers to is the peak value of current under load, or
was he talking about the peak positive value and peak negative value of the
voltage (?) in the sine wave, which is what I thought him to mean.
I suppose only he can say what he meant.
