Isolation b/w DAC & Power amplifier
masudasim
Aug 25, 2012
6
Hello
i am using NI DAC (6723) to drive QSC RMX 4050HD Power amplifier (PA) having input impedance of 10 kohm. I am generating 1-5KHz sinusoidal signals from my DAC.
1- I need some isolation & signal smoothing b/w DAC & 2kWatt PA.
2- Secondly, NI DAC has current limitation of 5mA/channel. I also desire to boost this capacity to say (10mA/channel) with some IC b/w DAC output & PA input.
Can any one kindly suggest some type of analog isolation IC/transformer which can do this job?
Best Regards
asim
CDRIVE
May 8, 2012
4,960
I just gotta know! What will you be doing with a 2KW sinewave?
CDRIVE
May 8, 2012
4,960
Hello
Best Regards
asim
I don't get any of this. If the input Z of your amp is 10KΩ it would require an input voltage of 100V to draw 10mA! :eek:
I just gotta ask: what does a smoothed sine wave look like?
edited: never mind, I see that it is a DAC output, so smoothing (usually know as filtering) does make sense.
CDRIVE
May 8, 2012
4,960
Hello
Best Regards
asim
I need to drive a acoustic transducer with this voltage
According to this the PA is driving the acoustic transducer. Your DAC needs to drive the 10KΩ input to the PA. You need a HiZ (>=1MΩ) input to an OpAmp to properly interface a DAC output.
Chris
Merlin3189
Aug 4, 2011
250
Not a comment - I just wonder what " b/w " means in this context.
.... isolation & signal smoothing b/w DAC & 2kWatt PA.
.... with some IC b/w DAC output & PA input.
I can't see how "bandwidth" or "black and white" would fit, so I wonder if there's another meaning I should know?
masudasim
Aug 25, 2012
6
Dear
Thanks for reply
"According to this the PA is driving the acoustic transducer. Your DAC needs to drive the 10KΩ input to the PA. You need a HiZ (>=1MΩ) input to an OpAmp to properly interface a DAC output"
Yes, Opamp with input impedance >1Mohm are easily available but problem is that i will not get isolation by using it b/w DAC and PA input
14,311
An audio transformer helps, see my first answer.
CDRIVE
May 8, 2012
4,960
As Harold said, you can use a small audio transformer. You'd connect it between the OpAmp output and the PA input.
Curious though.. Why do you need isolation?
Chris
