ISS108 diode information reqest
steven2
Jan 19, 2004
1,698
:)i did a google serch for information on this part and all i got was one page and everything i clicked on reqierd me to be a memeber or register and one page cannot be found and another the manufacter detail button dident work  so can anyone here go better and give me the information on this part without the hassels , i get from trying to find out about it from sites that dont serve to well, information for parts
steven2
Jan 19, 2004
1,698
i apolisise for the error in the part number its got a 1 in the number not i
indulis
Nov 21, 2005
488
Looks like D1 clamps the negative portion of the waveform that's AC coupled thru C4 and D2 is the rectifier.
The only thing you have to keep in mind when selecting the diode is PVI (peak inverse voltage) and the current rating. Use a Schottky diode for a lower forward drop (better efficiency) and much less reverse recovery time at the expense of higher junction capacitance... if you don't care about stuff like that, use any old fast recovery with the proper ratings.
What is the expected output current? Can't be much because of R1, the 1K (at 1mA of current that would be a 30V drop). You might consider a boost converter based on a 555 used as a PWM.
steven2
Jan 19, 2004
1,698
thankyou hot water wizard its great to hear from you again :)
audioguru2
Apr 6, 2004
12,026
steven said:
heres the circuit that part is in , can anyone tell me how much current it outputs
Hi Steven,
Each 74HC14 inverter has an output current of about 10mA with a 1V drop. So 4 in parallel make 40mA for half the total time and the 30V output will be about 2.6mA. The 5V average current will be about 17mA when the 30V has a 2.6mA load.
indulis
Nov 21, 2005
488
That will never happen... read my post above in regards to the value of R1!!
audioguru2
Apr 6, 2004
12,026
1mA through 1k is 1V, not 30V!
Sure it will provide about 2.6mA at 30V.
indulis
Nov 21, 2005
488
Yup......... your right!! I guess that's what happens when you get old and take a "stupid pill" in the morning!!
I have not built this circuit, but I did try to simulate it in 3 different simulators, Workbench, Intusoft and MicroSim, with the same results every time. I couldn't get a output voltage greater than around 10.5V... may I ask what the origin of the circuit is??
audioguru2
Apr 6, 2004
12,026
Did you sim it with a 74HC14 and not a CD74C14?
The 74HC14 has about 10 times the output current of the ordinary Cmos CD74C14.
indulis
Nov 21, 2005
488
Neither... an unlimited current square wave generator at frequencies from 20KHz to 300KHz.
audioguru2
Apr 6, 2004
12,026
Sorry, your frequency is far too low. The LC resonates at 2.140MHz and the circuit produces 1.5mA at 30VDC.
I found the project and its test results here:
http://www.interq.or.jp/japan/se-inoue/e_ckt27.htmView attachment 39316
ante1
Jan 24, 2004
4,138
Hi AG,
From what software have you got those nice diagrams that you attached?
audioguru2
Apr 6, 2004
12,026
Ante said:
Hi AG,
Hi Ante,
Usually I just press the keyboard's "Prt Scrn" button to copy what is in a link then paste the image into MS Paint where I crop and title it.
ante1
Jan 24, 2004
4,138
Hi AG,
Sure, I know that part pretty well but what software made the screen in the first place? Or, did you just find it on a website?  :D
