Markus Aaptnews
- Jan 1, 1970
- 0
Hey there everyone.
First post from a bit of an electronics newbie. Hope I'm not stepping on
anyone's toes.
Anyhow, I bought a little plasma globe from Jaycar recently (the batter
operated ones) and decied to plug it into a variable voltage transformer.
It worked, but it didn't produce as much arcing as other globes I've seen,
so I thought I'd try increasing the voltage, which had an immediate effect.
Great! I thought. 'I wonder what happens if I increase the voltage even
more'.
Well, let me tell you what happens - you blow something in the circuit board
is what happens.
I've tested the components in the circuit with a multimeter abd they seemed
to check out. Resistors still had correct value, Caps were still
non-conductive of DC current.
However, there is what looks like a transformer although it's not quite the
square shape I'm used to. It has 4 small leads and 1 larger lead (earth?).
It seems to have gone open circuit as there is conductance between all 4
pins.
I'd like to replace it, but it has no markings on it.
Any ideas what I replace it with? I have no idea what the ball park ratio
would be for these circuits. Is the size of the Tranny an indicator of
possible ratios?
The Tranny is about1 inch long by 2/3 inch wide and has a weird lobed shape
I'll try and post a link to a pic of the tranny later on, if that helps.
-Markus
anyone's toes.
more'.
is what happens.
pins.
possible ratios?
-Markus
