JBL LSR28P pro studio monitor pair no sound from tweeters
Martaine2005
May 12, 2015
5,318
Hello, is there a question?
If “why do the tweeters not work?” Is the question, maybe they’re blown.
Turn the volume low and put another small speaker in (testing only) See if you hear anything.
Martin
onedumbquestion
Apr 3, 2021
21
Martin
I read about two alternative methods First, connect a batter to the tweeter and see if it makes a popping sound on connect, then it's good Second, measure it's resistance Also could the problem be I plugged a stereo source into the input jack on back Maybe it needs to be mono?
onedumbquestion
Apr 3, 2021
21
I took one of the tweeters out to test It's blown You can see where the winding burned out at the connector Can I get it fixed
