JBL onbeat xtreme only works when warm.
Status
Not open for further replies.
Rick in the desert
Mar 6, 2021
Hi there. I am new to this forum.
I got a JBL onbeat xtreme bluetooth dock speaker that started to behave strange recently. One day the sound started cracking and would only produce sound in like half a second intervals. I tried an old trick by putting it out under the sun for several hours until the casing was really hot and surprisingly it started to work fine. I played it for several hours into the evening and when the evening chill kicked in the problem started again. Are there any components on the PCB known for being temp sensitive that I could try to locate and replace?
Many thanks in advance for any ideas.
Regards
Rick
Martaine2005
May 12, 2015
5,318
Welcome to EP Rick,
I have never heard the old trick of putting it in the sun for a while. Although I have heard of putting in a freezer.
That said, it sure sounds like a loose connection that is possibly expanding in heat. Either way you’ll need to open the unit and have a real good, close-up visual inspection of the board. You’ll be looking for dry/cracked solder joints, loose connections or obviously damaged components.
If you see any of the above, take some close up photos and post them here if you need further help.
Martin
nextike
Nov 30, 2023
Regards
Rick
Hi! Have you found solution for that problem? We have 2 of this speaker and we have the same problem with these. Thank you in advance!
Delta Prime
Jul 29, 2020
2,996
Yes. You have to imagine these things get dropped,kicked around. Things are going to wiggle loose.
bubu23ant
Feb 28, 2026
i have the same problem there are gaps of 0.2 seconds sometimes between music i thought it was from the heat,doesnt matter connected with cable of bluetooth,what is the reason
Status
