JK Flip-Flop Toggles Twice from One Button Press
eva_402
Mar 13, 2026
4
Hi everyone,
I’m using a JK flip-flop for a simple state control circuit. Pressing the push button should toggle once, but sometimes the output changes twice or returns to the previous state.
The button has only a resistor and capacitor debounce network.
Questions:
  1. Is the issue likely incomplete debouncing or clock edge sensitivity?
  2. Would a Schmitt trigger between the button and clock input solve it properly?
  3. On the PCB, should manual input traces be protected from nearby switching lines?
danadak
Feb 19, 2021
1,104
RC approaches, without using a Schmidt trigger gate or comparator with hysteresis can
generate problems due to excessive rise and fall times associated with the C charging.
And hanging a large C off a cmos input pin can cause potential damage to cmos input
structure during supply collapse on turn off. Not advised, or add a series R between cap
and gate input to limit current thru input structure parasitic diodes and or ESD protection
circuitry.
And of course one can always do it with code :
The above bounces the button in and out before target code gets executed. Easily modified to just
+ edge needed to execute target code.
Classic
danadak
Feb 19, 2021
1,104
Code eliminate need for J-K possibly, without schematic we need more complete
description. Is OP toggling J-K with button or sampling button with J-K and / or
using it as part of his state machine.....more info needed.
@OP
I would say incomplete debouncing. Certainly schmidt could help if you need
JK for other circuit uses. Is it just there for button state ? PCB, if inputs are driven
by high Z sources then yes C coupled pickup could be a problem.
Note circuit incomplete, it needs a series R bewteen RC junction and gate input, in case
supply collapse on turn off rapidly dischrging cap thru input protection circuitry in CMOS
logic can cause damage.
jonas123
Apr 13, 2026
6
Hi everyone,
Questions:
What you describe sounds more like incomplete debouncing than JK clock sensitivity. A JK FF will happily react to every threshold crossing, so a bouncing button can look like multiple clock edges and cause double toggles.
An RC alone is often not enough because the clock input may linger in the undefined region. Adding a Schmitt trigger after the RC is usually the cleaner fix.
For PCB layout: yes, keep manual input traces away from fast switching nodes, clocks, gate drive traces, and high dI/dt paths. Add a solid ground reference and keep the button line short if possible.
bidrohini
Feb 1, 2023
221
This sounds very much like switch bounce reaching the clock input. A JK flip-flop will respond to clock edges, so if the button produces several fast transitions, the output can toggle more than once.
  1. Would a Schmitt trigger between the button and clock input solve it properly?
An RC network helps, but it does not always create a clean digital edge. A Schmitt trigger buffer between the button/RC network and the flip-flop clock input is usually a much better solution because it cleans up the slow or noisy transition.
  1. On the PCB, should manual input traces be protected from nearby switching lines?
On the PCB, I would keep the manual clock/input trace away from switching signals, motor lines, relay traces, or fast digital edges. Also keep the pull-up/pull-down, capacitor, and Schmitt trigger close to the flip-flop input. Read these routing guidelines: https://www.pcbway.com/blog/PCB_Design_Layout/Common_Rules_for_PCB_Routing_29d86598.html
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
The only "bullet-proof" way to de-bounce a manually-operated switch is to use a SPDT switch wired to control a simple set/reset flip flop. Some J-K flip-flops have separate set and reset inputs that can be used to implement a set/reset flip-flop. If you use one of these, disable the clock and the J and K inputs by connecting them to circuit common or ground.
There is extensive information available on how to de-bounce mechanical switches using NAND, NOR, and INVERTER gates, but I can describe circuits if you don't want to do the research. My personal favorite method uses a pair of cross-coupled NAND gates to create bounce-less switch transitions. Cross-coupled INVERTERS use the same circuit as NAND gate implementations, but the switch momentarily "short-circuits" one of the INVERTER outputs when the switch changes states. CMOS INVERTERS usually limit the momentary short-circuit current without damage. The short-circuit quickly goes away after the circuit changes states. but some "purists" object to short-circuiting outputs, even though its temporary. Your mileage (or kilometers) may vary. The NAND gate implementation is fool-proof but the NOR gate version is more complicated because the n.o and n.c switch contacts must be pulled dpwm to logic-zero and the moving switch contact connected to a logic-one level.
The biggest advantage of using an R/S flip-flop to de-bounce a SPDT switch is simplicity: only two (optional) pull-up resostprs are required.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
I just now found one of my missing "round tuits" and read the paper linked to in @Harald Kapp's first response. Very nice analysis of the switch de-bouncie problem. including software solutions. Ignore the software approach if at all possible and use the RS flip-flop instead. Don't waste valuable time trying to get the software de-bounce routine working properly when a simple hardware approach will allow you to continue with your project. Unless of course you are stuck with using a SPST switch with bouncy contacts. Good luck with that...
