- Joined
- Jan 21, 2010
- Messages
- 25,510
How do I determine which resistor value I need?
Something less than 1k, and something more than zero
Because the inductor is essentially an unknown, the required resistor can't easily be calculated. If you have more 1k resistors, try 2 in parallel, or three. If that still fails, try 220 ohms, or even 100 ohms. I'd be looking at the highest value which gives a reasonable light output.
As discussed above, the circuit is hard on the transistor, a higher base resistor will reduce this a little.
