Kenwood TS 830S
Nemo1956
Sep 5, 2016
34
Im not having a good month.
Now my much beloved TS830S has gone tits up on my.
It started to fail two weeks ago when i switched it on no RF output. So I left it running for about 1 hr and then 60 watts. OK that will do. But this weekend nothing at all. so I took some measurements only to find that the 12AY7 valve base had problems. So I pulled the RF board out and I found cracks around the solder joints. The pins where in a mess so I had to remove the base and clean up all the pins. Put it back and re-soldered it in. But as the board was out I took some other measurements and found the 12AY7 grid leak resistor was open circuit and the one of the two cathode resistors had gone a bit high. Both replaced. So i put it all back together. Switched it on and still on RF output but then I could see the HT volts dropping to 350 volt and not 850 volts.
I think I may have a short in one of the PA valve now ?
Has any one had anything like this???
Oh well it is over 25 years old so I guess it would like a bit of attention and TLC.
14,487
I have a problem with my old TS830 at the moment so I need to take it to bits and find the problem with it. No RF at all on transmit.
any mode ? AM, SSB, CW ?
start with seeing what is coming out of the pre-driver and driver stages
From memory, they had a pair 6146B's as the finals
I assume you have a service manual ?, they are readily available online
your one is only 25 yr old ? ..... gosh those things go back 40+ yrs
Nemo1956
Sep 5, 2016
34
Hi there. Yes it has 6146's in the final and a 12?? in the driver stage. I replaced the valves with a second set but still nothing. Guess I need to strip it.
14,487
I haven't looked at the diagram .... maybe a 12AX7 .... think they were often used as low power transmitting tubes
been years since I was regularly playing with tube tech
also make sure ALL switches ... band switching etc are all clean, crappy worn contacts can do all sorts of weird things
Nemo1956
Sep 5, 2016
34
I have looked at all the switches and all seem to be in good order and clean. Yes the 12AX7 Could not remember it. Like you its been some time since I have worked on vintage equipment. But Im vintage as well. LOL I think the problem is the driver section as I also don't see any drive level. I need to take it to bits and have a good look at it. I love my 830 it's one of the better radios of it's day.
Nemo1956
Sep 5, 2016
34
dorke
Jun 20, 2015
2,342
Swatde kharp.
I haven't ever used this SSB/CW HAM radio.
Something seems to be wrong with your description:
Where did you get the idea that HT of the 12AY7 (dual Triode audio)should be 850Volts?
350V sounds o.k(even a bit high).
Did you check the output in CW mode?
What are you using to check the output power?
Is the receiver part working?
Do you have a schematic diagram or service manual of the unit?
Do you have a scope?
14,487
Swatde kharp.
I have moved more info from another thread to this one .... @dorke have a reread from the new start of the thread and it may now make a bit more sense to you
and some of your Q's will be answered .... like yes we got a manual :)
Paul and I had started talking about this problem some days ago .... I think he typo'ed in his post above and forgot the other thread and that I said that it was a 12AX7
(not a 12AY7)
The 12AX7 was a common transmitter driver tube for a single or pair of 6146B finals
service manual link on my home page site
http://www.sydneystormcity.com/TS830S_Service_Manual.pdf
dorke
Jun 20, 2015
2,342
Thanks Dave,
From the SM :
V1,the driver Pentode is 12BY7A .
So still, HT of 350V looks o.k.(a bit high).
Please check all DC voltages on V1 with a DVM ,including the heater(ACV!)
per the SM :
Nemo1956
Sep 5, 2016
34
Hi all Many thanks to you all for your kind replays.
Over the weekend I had a very deep look at this. My first thoughts where that I miss aligned the switch in the PA stage but no it's ok but the coupler will need to be replaces soon as it has cracked. I measured all around the Driver valve (12BY7) and it looked ok so I moved on to the PA section. There I found that they was no cathode volt and the anode volts are 300 +/- volts short when in transmit. This I traced to the power supply board and found no end of problems here. Resistors open circuit and high in value the doubler stage the capacitor was open circuit and many others like it or leaking. I just don't know how this radio worked at all in this state.
Anyway I need to order some new capacitors now as I have replaced all the resistors now.
I Let you all know how i Get on when I get the new parts.
Thanks again for all your help.
Paul
Nemo1956
Sep 5, 2016
34
Up date for you all.
Sadly after doing all this work on my 830. I have discovered that the mains transformer is the main source of the problems. Its got a shorted turn on the HV winding. And now gets very hot after only running for 30 seconds. Very sad so that makes my much loved TS830 scrap. I had through of rewinding it but its the second winding after the primary winding so I would have to completely dismantle the thing to do it. Then get it rewound. So I have decided that enough it can't do any more for it.
14,487
far out, that's a total bummer :(
maybe you could look around for some one that is selling one for parts and rat out the tramsformer
duke37
Jan 9, 2011
5,364
How did you determine that the shorted turn is on the HV winding? Shorting to an adjacent turn will make very little difference to the winding resistance and all windings are inductively coupled so it is difficult to find the origin.
Nemo1956
Sep 5, 2016
34
I measured it to one of the other winding it should be open circuit but it it reading around 30 ohms and the transformer is getting very hot indeed after a very short time.
Nemo1956
Sep 5, 2016
34
Yes I have had a look for one on ebay but nothing there at all. but some other boards for sale but no transformer. Maybe it a common fault on these old radios after it's been running for some years continuously like i think this one has.
Nemo1956
Sep 5, 2016
34
Hi all. Update for you all. I removed the damaged transformer and had a good look at it but can't see anything that shows me where the problem is.
As i live in Thailand there are many places that will rewind a motor for you so I just took it up to the closest one and said can you find the fault on here. I told him I think it has a shorted turn between two windings. At first he just said no can not do but after having a longer chat with him. He said if I remove the bobbin he would look at it.
This I did. (not an easy task) Them took it back. He looked at and said come back in two days.
Well that was last week but I have not had time to go and see what he has done with it.
Nemo1956
Sep 5, 2016
34
Hi all. It's been some time since I have reported the latest on my poor TS830S.
Well I have replaced the mains transformer with one I got on eBay. The guy here has rewound my transformer but I got a replacement one now.
I have thrown a lot of money at my 830S as I won't it back working.
I have replaced the EHT smoothing caps twice as the first set had a faulty one and only ran for about five minutes before exploding. It tuned out that the plus and minus markings on that cap was reversed.so that was that. Cheap caps fron China. Won't be going to that supplier again. But in all fearless they did replace them both. But by that time I had others.
Also replaced all the valves in the PA and the driver so they are all good.
I also replaced most of the coupling capacitors between the driver and PA and the output caps.
Ok should be good now.
Well no. Still has the same fault as before.
I have had a good look at the solder joints around the driver and yes there was some problems there but that's all sorted. I have cleaned all the switches and tested there connections and after cleanings they all worKing as they should.
I can see the signals on my scope and that seam to be correct when it's working but when not I can trace the signal to the grid of the PA. But no output.
So what is this dam fault and where is it.
Help.
Paul
shri
Jul 28, 2022
8
Hello everyone, my name is Ivan LZ2IX. I am repairing an kenwood TS830M transceiver. The problem is there is no output power. On TX mode 335V the anode 12BY7A, pin 7 become 2.5 volts. I would like to consult with you if anyone knows this problem. What I have done so far:
All electrolytic capacitors in the transceiver have been replaced, also 2X 100M/500V.
RF block all the resistors in the circuit of the driver tube 12BY7A. Here there was a burnt 100K in the circuit of G2 and a changed value in the cathode circuit. For more security, I replaced all of them with new ones .../2watts. All voltages supplying the RF unit are stable and correct, they do not change during RX/TX. I cleaned all contacts on the band selector and in the output stage as well. All tubes 12BY7A and 2х6146Б have been checked and work normally. I put them on another TS820 transceiver and tested them, they give 100 watts of power. I cleaned the antenna relay contacts and the relay on the AF unit. Output stage voltages are ok cathode resistors are ok. The solder joints of the tubes are re-soldered. At the output of the mixer in the circuit of G1 on 12BY7A are 2.5Vpp signal with the correct frequency. Does anyone have any idea what's going on, I'm out of ideas.
shri
Jul 28, 2022
8
I am new to this forum and would like to ask for your help. For me, I am a radio technician for a long time and I repairing radio stations for more than 20 years. In this case I really don't know where to look for the problem. I took multiple measurements looking with an oscilloscope. All driver tube voltages are within the normal range of RX mode. Only the anode voltage of TX mode the tube 12BY7A pin7 changes, the other voltages are correct.
