Kwh meter
paulmars
Aug 30, 2016
19
Hi all,i need a kwh meter to record power used on a 26a 240vac kiln. It does cycle off and on & has different heat settings. so i cant just use 26a x hrs.
I see so many electronic meters for sale and none really have a lot of reviews. Priced from 10 to 25$ and more. Are they any good? Which ones?
So I decided to just buy one of those used mechanical house mtrs and box,but that will cost me 75 to 100$. Which is probably overkill.
Any thoughts? I prefer one i can reset to zero every month, but might settle for one that i cant .
p
Delta Prime
Jul 29, 2020
2,996
At your price range I cannot recommend anything.
You want to research" AC kilowatt-hour Data logger, recorder" . It has all the features you would like.
kellys_eye
Jun 25, 2010
6,512
There are many, many modules that can show multiple AC voltage signals (volts, amps, kWhr, frequency - and all simultaneously) and they use an external pick-up coil to measure the current (current transformer) that needs to have the 'hot' wire from the supply voltage fed through the centre of the coil so it can induce a signal to be measured.
Here's the first one I saw on eBay: https://www.ebay.co.uk/itm/252636621057?hash=item3ad250e901:g:p7sAAOSwcUBYJcP9&amdata=enc:AQAIAAAA4IK+nOOdLnfrNHtFMaRj4NLcCSgbUsK3RXPc+MD5+E0QTfeung3fhBLbaOKzep+8/H/a08RlGNTfOfTa+ymZz9YN6Je/I1fX1MmbWIrEpFvXpGYqkmyyR3/l6nKec5cftby9mmUqat7yzzvn10RmHwlACIywzA42FEYWUE5NAgSe8RLU/FA4Wx/6VCmuoTbFuLBFnfjyb4e39+fRbcQXJROF591jytG8bVHboszj+cdRB1TN8Z63KJp+eTcMdXKy94foC+FdcrwR+th+p+Yea36U1eI1pLJPVdyVR7MWSSXN|tkp:Bk9SR-7YibC2Yg
Scroll down the listing to see how the model(s) are connected and the bits it comes with.
Delta Prime
Jul 29, 2020
2,996
If you're not so frugal you can try this one
