Typewriter LCD display repair
Astro13
Feb 3, 2024
11
IMG_0883.jpegHey, I acquired a vintage computerized typewriter and it works perfectly, except the display. I suspect it’s the zebra cable, but I have no idea how to replace that. Also a fix would be appreciated because parts for this machine basically don’t exist anymore.
Appears to be a standard 16 x 2 LCD display.
Number of connections on the pcb suggest this (16)
Below is link to a standard 1602 Arduino style LCD. (Not the one with I2C )
They are relatively cheap so you could get one and try it.
This one is Ebay but one can get them almost anywhere online.
https://www.ebay.com.au/itm/276236911901
Astro13
Feb 3, 2024
11
I don’t know how I would connect that, seems to be slightly proprietary on the typewriters endIMG_0886.jpeg
Get a clear close up shot of the rear side of the LCD with the (grey) ribbon cable and any markings on the rear of the LCD where the(grey) ribbon cable connects.
If you took the time to look at the links I showed of the basic 1602 LCD, you would see the terminal connections marked.
Point being, if the old original has markings, chances are they'll be the same and all that is needed is to connect new unit with the matching markings.
If not, then someone with experience in these should be able to work it out using any cross reference if different.
Note that RCL (marking on back of LCD) is an LCD manufacturer.
Guessing MBC16202 is a model number but obviously too old to get a search result.
Edit: I see the first photo, 16 pins are visible.
Whereas in the final shot of the LCD rear, only 14 are connected.
This might be quite normal as the last 2 pins of the 16 I quoted will be the on-board LED which the original does not have.(no problem)
kellys_eye
Jun 25, 2010
6,512
Have you tried applying light pressure along the edge of the ribbon that connects directly to the LCD itself (both on the board and at the LCD glass)? If you can 'encourage' more of the characters to appear you might get away with some added pressure using soft rubber strips at the pressure points. Not a permanent fix but a get-you-by.
As per the above, the display does look to be in the standard format and since the (off board) ribbon looks to be numbered it will likely match the same numbering scheme as the LCD advised.
Astro13
Feb 3, 2024
11
And I would just solder some jumper wires and all should be well, however, when I slide the contrast potentiometer most of the display lights up, I’m just hoping it’s not the graphics chip
Astro13
Feb 3, 2024
11
Here you go, I see a few labels but not all of them are labeled
Astro13
Feb 3, 2024
11
I mean, it’s a typewriter, I don’t need it functioning per say, a temporary fix is not necessary. I have several computers. But it’s cool to have, and put on a shelf somewhere, especially useful when my godforsaken printer decides to fudge up again
H2814D
Nov 4, 2017
258
So I have messed around with LCD displays on a few occasions. Boat navigation displays, knot meters, depth sounders, LCD clocks, etc. The appearance of your display may indicate a voltage/current supply problem. You aren't getting enough of it to activate the segments/numerals on the display. I wouldn't mess with replacing or messing around with that display module quite yet. You might damage the ribbon cables. Before that, I would check the power supply circuit to that module. These display problems are often caused by failed/failing capacitors in that circuit. Look at those first.
Astro13
Feb 3, 2024
11
Crap, thought I was going to fix this easier then that.
Was hoping there were more markings than that, already well aware there were 14 pins and which way an ide socket is numbered but that wasn't the connection I was referring to.
Rather the one on the lcd itself......... where it connects to the pcb with the (should I say LIGHT grey cable) and ending at cn21....connection at the LCD is too far away to make out and ...any numbers which might be under the ribbon cable are covered by the cable.
Only chance now is to try to find a schematic pinout of that particular model either from RCL themselves or floating around somewhere on the web.
Astro13
Feb 3, 2024
11
I will take a look, but I doubt the internet will have anything for me, this is a pretty rare machine.
If you include the info on model etc. perhaps it will help...?????? or is it a secret.?
Should be a name tag somewhere on the device giving the "exact" details on model etc.
Delta Prime
Jul 29, 2020
2,989
Screenshot_20240204_155636.jpgYou can probably find one that is selling just for parts.Use only as reference please....
H2814D
Nov 4, 2017
258
No worries, Astro. Let's do the easy stuff first though. For now, take very clear photos of the front and back of the circuit boards in that thing. The larger one that is still in the machine and the smaller board the display module is connected to. It looks like the board in the machine is held in by screws. In the photos you take, try and concentrate on the electrolytic capacitors on those boards, but make sure all of the boards are shown. I don't know if you know what they (capacitors) are, so if not, let us know and we will help you.
Are you familiar with visual signs of failure for capacitors? If not, try and research that information. It may help in the diagnosis.
One other thing. In the very first photo you supplied, and just above the grey colored switch(?), there appears to be a darkening of the wire solder joints there. Is that the case, or is it just the way the photo was taken?
It's an LCD fault.
If you look at the display photo in the first photo you'll see the same scan lines are missing in all.
Anyhow, I'll leave you to it.
H2814D
Nov 4, 2017
258
It's an LCD fault.
Thanks, Bluejets, but Astro mentioned the majority of the display "lights up" when adjusting the "contrast potentiometer." This is the clue that leads me to believe the module is still functioning properly.
