Gavin said:
I have 2 x 120 Kva UPS ( 3 phase 400V ) supplying a computer room to
provide me with n + 1 in event of a power failugeneratorer the load is now
100 Kva but we have a problem with leading the power factor. I cannot put
a big motor on the UPS to correct it. Does anyone know of any other ways
that can correct this ?
Regards
Gavin
Gavin,
I'm guessing from your original post, and what I have gathered from the
followups I get here, I don't seem to be getting them all, that your
problem is a 3 phase 400Vac(?480 maybe? are you in the US or another
country?)feed into a ups system that feeds out to, by the sounds of things,
one heck of a computer room. You have a leading power factor due to the
load placed.
There is always the missing info thing to consider, but I'm guessing your
UPS is an active switching station, and inactive power unit (like a
generator that sits idle till it is needed and a small battery and
converter set up that holds power while the generator gets up and running).
If that is the case, an active power unit would be the best way to go. (the
computers run off a battery pack and converter full time, and the generator
kicks on when needed to charge the batteries) All depends on how much your
company wants to lay out for a battery room, and converter system. When it
comes right down to it, we all have to watch what we spend, even if it is
well worth it.
If you are simply looking for a cost effective way to beat a leading power
factor, your local power utility company (PUC) can probably supply the
engineering specs, free or at a modest charge, for a capacitor bank that
will do the job. Despite how much every tech in the world gripes about
them, all PUC's are helpful when it saves them money, and getting rid of a
leading power factor draw will save them money. Just call them and ask to
speak with an engineer in the generation or maybe distribution (depends on
the PUC I'd start with generation, explain what I needed, and go from
there) division. And be prepared to wait a few minutes till you get through
to someone that has some idea what you are talking about. (So don't make
the phone call on your lunch break
Hope this helps, and if not, please drop a reply, or email so we can get
some more specs, and we *will* find something that does.
Mike Undercofler
