Led display Digital Voltmeter question
bonanz1
Sep 11, 2003
24
This circuit came up at the perfect time! couldnt have asked for a more perfect design for what i need right now, only problem is i don't have a -5 volt supply.  What would happen if i grounded that pin rather than using -5.  would that simply not allow for negative voltages to be measured? because i only need positive for my application. or is there a simple way to make a negative supply from only a +5 being available?
thanks
bonanz
Project Link: http://www.electronics-lab.com/projects/test/001/index.html
gsmaster1
Sep 13, 2003
72
You can use the TC7660 (from microchip I think ???) which is for this job. It takes gnd and +5V and gives you your -5V. ;)
mixos1
Administrator
Jul 13, 2003
581
If you ground -5V pin, and apply +5V to the pin 3 then it will work nice :D for measuring positive voltages (i already tried it). I am not sure what will happen with negative voltages, i haven't tried it.
Hope that helps a bit.
bonanz1
Sep 11, 2003
24
okay great, because i only need the circuit to measure positive voltages, the input will never go negative. when you say pin 3 do you mean pin 3 on the pcb? not on the chip right?
mixos1
Administrator
Jul 13, 2003
581
Right... the pin 3 that is indicated with +5V at schematic.
mozikluv1
Aug 18, 2003
43
:)hi bonanz,
you said you would be measuring only positive voltages, now what would happen if you accidentally reverse your probe. wont your voltmeter get burned? i believe one of the reson why this device was designed to have a dual supply is bcoz of that. if you reverse the probe your display will have a negative sign.
since you said you only have a 5v positive supply, try using LM7905 to get a 5v negative supply.
hope this solves your problem.
mozikluv1
Aug 18, 2003
43
:)hi bonanz,
sorry i was not able to complete my reply, one way to solve your -5v swupply source is to use a 10v transfo. this is how you do it,
1. series 2 resistors
2. shunt the resistors across the rectified output
3. from the junction of the 2 resistors, this is where you tap your ground
4. connect the usual filters
5. connect your 7805 for +5v and 7905 for -5v
suggested resistance value is 47K 2w
hope you can benifit from this :)
bonanz1
Sep 11, 2003
24
Okay i've done some playing around with this circuit and i cannot get it to work for my application. I'm not worried about switching terminals because i am not using it as a typical dmm i'm using it to display a voltage in a circuit that will always be positive. I am using the LM2907 frequency to voltage converter and have it convigured so that the output voltage is linearly proportional to the input frequency (ie 200mv ~ 200hz) the max freqency i'd measure would be about 1200Hz which would correspond to 1.2v work perfectly on the 2v scale and i would just leave the decimal points unconnected. I have hooked up the project circuit, and did a test on a voltage divider to see if it was measuring correctly and it did measure the voltage, but i only had to connect terminal one to the voltage point and did not connect terminal 2 to anything and the voltage displayed correctly. (this is btw with the negative supply grounded). The LM2907 freq to voltage converter circuit i have completely working and outputing the corresponding voltage when i use a regular multimeter, but i would like to integrate this circuit with it to have a permanent display. any help would be appreciated.
bonanz
billy2
Oct 23, 2003
101
I would really appreciate if someone could tell me a way to change the default 0-2,0-20,0-200,0-2000 scales to a custom one, for example
0-30 V (or 0-40, it doesn't matter)
because I want to integrate this circuit to the Stabilized 0-30V 0-3 A Power Supply that appears on the entry page of this site. I am about
to design a new PCB with a complete solution for a lab PSU.
Thanks ! :)
mixos1
Administrator
Jul 13, 2003
581
I use this digital voltmeter with this
3-30V power supply: http://www.electronics-lab.com/projects/power/032/index.html
If you configure it at 200V range (R3 = 12K) then it will measure from 0-30V with one decimal point precision.
for 4,1V will display: X04.1
for 10,1V will display: X10.1
where X indicates that the first display is OFF
I think this configuration is ideal for your power supply.
If you finally draw a PCB for a complete bench PSU solution i will be happy to host it under the power supply's page ;) .
MP1
Dec 7, 2003
3,397
I have not yet tried this, but one should be able to have auto ranging with comparators and a 4066 cmos switch.
MP
billy2
Oct 23, 2003
101
I tried to build the L.D.D.V. yesterday, using a breadboard and
I came up with peculiar readings on the LEDs. ??? I had followed the
schematic from smartkit.
I thought that I had a false ICL7107 and I dismounted the
components. :-[
Today I thought to check the data sheets of ICL7107 and MAN6960 in order to cross-check the connections. Found [glow=red,2,300]inconsistencies[/glow] in the
article schematic ! >:(
For example for the 1's display :
Article : ICL(6) -> MAN(10)
Should be : ICL(6) -> MAN(9)
another example :
Article : ICL(34)
Should be ICL(25) -> MAN(1) and so on... there are many there.
Moreover, the R1 should be 100K, not 180K, I refer to the datasheet
and the "Digital Voltmeter" project
Finally, the LCD dot, is pin number 5, emitted in the schematic.
I am about to search all the errors now and report back later,
after I will rebuild the voltmeter.
I attach the data sheets for further reference. 8)
ICL_and_MAN.zip
  • ICL_and_MAN.zip
MP1
Dec 7, 2003
3,397
Billy, I look forward to your findings when you are finished. I had planned to use this circuit as part of a larger project. Glad you found the bugs in it. I had also downloaded the data sheets, but I had not yet compared them with the project schematic. Good find!
MP
mixos1
Administrator
Jul 13, 2003
581
Great Work Billy. Thanks for doing that :D .
Sometime ago an internet friend told me that the kit companies are making some small faults (not by chance) on schematics to prevend them from copying :eek: ! If you relly on the PCB, everything will work nice, becuase it's a copy of the original (already worked) board. So you can use it to debug the schematic.
Please do the debuging and make the changes to the schematic... i will be very happy to see it here!
JacintChapo1
Jan 6, 2004
Hi!
Today I pieced together this V meter, and what can I say, it works verry well. ;D
billy2
Oct 23, 2003
101
Did you make it on a breadboard using the schematic or just
build the PCB at once ?
maestrodamuz1
Nov 29, 2003
18
I have checked out those inconsistensies and I have prepared the corrections, you guys will get them soon.
maestrodamuz1
Nov 29, 2003
18
I have done serious work on the volt meter, I have really had problems getting a -5v supply out of a 9v battery. I tried using the replacement for the cd4009 as indicated in the data sheet from intersil, cd 4049 all to no avail. I actually wanetd to run the unit from a 9v battery for portability sake, now i have had to revert to the good old transformer and using an LM 317T and LM 7905 in conjuction wit 2 polar capacitors of differnt capacitances I have been able to get the 2 voltages (-5v and +5v) now my problem is calibration, am using a 1k instead of a 1.2k to get the 0-2000v scale,(That is the only scale am using) I shall find out 2 nite if it will work. :'(
MP1
Dec 7, 2003
3,397
Here is a circuit that might help with the negative supply. Easy to find parts. You might have to tweak the values a little for your application.
MP
