Led electronic clock kit
Lene Larsen
Feb 1, 2018
28
Hi.
This clock is tricking me. Can anyone explain, if I do something wrong?
Is it impossible to solder with an ordinary iron solder?
If you look at the picture with only one component, is there a special way to solder it? I noticed the legs must be placed as seen in the circuit at the print in one directino, but is there up and down, I mean can it be turned 180 degrees in the wrong way?
Looking foreward for an answer, maybe it can help me.
kellys_eye
Jun 25, 2010
6,512
The legs are not 'square' on the body so the switch can only go in one of two ways, both of which will work.
There should be no problem soldering any parts if you use the proper technique.
Note that it is IMPERITIVE that the IC is placed correctly - you only get one chance!
AnalogKid
Jun 10, 2015
3,058
This type is switch is symmetrical. It can be turned 180 degrees and still will work in the circuit.
ak
Lene Larsen
Feb 1, 2018
28
Thank you for answering me. There is not the same number at the switches, but I think they are alike each other. I will try again with a more thin tin thread. I also noticed, it is important to fill out the printhole. I am near the goal, there is some digital led light, but the clock does not work as a clock.
shrtrnd
Jan 15, 2010
3,902
You might want to tell us the numbers on the switches (and a manufacturer's logo, if there is one).
The picture you posted is of a 'tactile switch'.
There MAY be different numbers on the switches because there may be 'normally open' (NO), and 'normally closed' (NC), versions of these switches in your kit.
That might be important, depending on how your kit circuit is designed.
Lene Larsen
Feb 1, 2018
28
[QUOTE = "shrtrnd, post: 1777505, medlem: 11429"] Du vil måske fortælle os tallene på kontakterne (og producentens logo, hvis der er en).
Billedet du har lagt ud er af en 'taktil switch'.
Der kan være forskellige tal på kontakterne, fordi der kan være 'normalt åben' (NO) og 'normalt lukket' (NC), versioner af disse kontakter i dit kit.
Det kan være vigtigt, afhængigt af hvordan dit kit kredsløb er designet. [/ QUOTE]
Lene Larsen
Feb 1, 2018
28
Hi.
I am very glad for all of the answers, I know it is just a little cheap clock, but I will love to make it. And later I will love to make it together with my teens in school and my teens in family. Here is some more picture, the information from you is very useful for me.
Lene Larsen
Feb 1, 2018
28
The name of the kit at the order is DIY Kit Digital LED Production Clock Kits C51 4 Bits Electronic.
The name of the kid at the emballage is FEDA15A37
Lene Larsen
Feb 1, 2018
28
The number of the switches - I think GY (maybe OY) and 48 at one of them and GY (OY) and 44 at the other
kellys_eye
Jun 25, 2010
6,512
The schematic shows both switches as 'push-to-make' although I can't find any specs for the numbers you quote. Do you have a test meter you can check them with?
Lene Larsen
Feb 1, 2018
28
Hi again.
It is very strange, the tactile switches have different numbers in the kits. Maybe it does not mean a thing. But thank for your help, I have now made my clock, although I in the start broke 3 kits. But I am lucky now, Practice makes perfect. I use a 9V batteri, but it works fine. :) clock.jpg
