LED strip with waving sensor
wizzard73
Apr 4, 2024
5
I have a USB LED strip with a waving sensor. The problem is that it turns on automatically when plugged in. I want to change this behavior somehow to stay off and turn on only via sensor input data (waved the hand). Unfortunately I didnt find any diagram/datasheet/schema for the board. My question is: Is there a way to alter the board's behavior to not power on when the electricity is switched on, but only via wave sensor (hand wave)?
Thanks in advance for any help!
Data on the back of the board:
PM-DLGD230711-V1.0
SN:20230712
Photos of the board and the LED strip are attached.
Martaine2005
May 12, 2015
5,276
Did this work properly from new and now has a problem?.
If it’s new, have you tried leaving the LEDs on for a period of time to see if the sensor requires start up time?.
Or holding your hand over the sensor for 30 seconds?.
wizzard73
Apr 4, 2024
5
the led is new. it will not turn off until I will wave my hand in front of the sensor. I want to change this behavior. Right now I can turn it off by hand once the electricity is on, but I want to keep it off whenever the electricity goes off and on in the house/room where this strip is installed.
wizzard73
Apr 4, 2024
5
The function you would like is more than likely in the code on the microcontroller.
Totally understand. Thanks for help. I also was thinking about this, but wanted to try if there is any option to change the behavior by "resoldering" something on the board and needed a confirmation from someone that knows better.
73's de Edd
Aug 21, 2015
3,730
Sir Wizzard 73 . . . . .
On my part . . . . I need more clarification on the need that you specify, unless the power source is disconnected or is having it supplied with a switched AC power source.
Also is the power source coming in from a USB connector into a cable to this LED strip control box, with its LED + photocell waving detector.
SOME OBSERVATIONs AND TALKING POINTS . . . . . .
On the top side of the PCB components mounted side.
At the top, a white wire is power ground and the right side RED wire should be +5VDC , if being supplied from a USB connector, but WHAT is that USB connection being made into ? a piece of computer equipment or ? a stand alone wall wart USB power supply ? and are these then just being left continually plugged into the power source, or is there an additional in line power switch also being involved ?
OTHERWISE . . . .why wouldn't just a hand wave ,suffice to turn off the light strip, if the LED strip turns on all of its LED's upon initial powering up. Then the LEDs are being off until a hand wave turns them on and then off, as needed later on.
THE WAY I AM SEEING ITS COMPONENTS RELEVANCE . . . . . .
+5VDC is coming in at the top 2 wires and a A7 series diode in the + line, used to protect from any mis- polarized power supply application.
U3 pads are for a power transistor or regulator , with it apparently not ending up being used.
Down the left side of the board I am seeing Q1 and Q3 A2 type support transistors. Their circuit function relevance unknown at this stage of the mystery.
Travel across the board to find LD1 surface mount visible LED. With two LED's being used, I am now wanting to see the center top LED as being an INFRARED emitter that shoots its beam / pattern upward, to then be hand reflected down upon the INFRARED detector at center bottom, just below it.
Enter the presence of yet the 3rd surface mount transistor, a J3Y, suspicioned as aiding in interfacing between the output of the INFRARED sensor and the input of the 8 pin IC U1 ???
OR it could be the power interface between the U1 I.C. and the LED string. . . . .
BU T T T T T T T T . . . .moi . . .( I ) am real l l l l y wanting to see the bottom RED LED string wire continually getting power and its WHITE companion wire passing up to the collectors of the two A2 transistors and incoming base drive into the pair, will be driving them into full conduction and getting a ground connection at emitters . . .VOILA . . . . THERE IS LIGHT !
Staying on, until base drive from U1, disappears, after a hand wave reflection.
Confirm that the 8 pin I.C. is assigned as being IC1 or ? and is there being any ID marking on it ?.
Find pin 1 of that I.C. by its recess circle close to it or a U-gap molded in the case on one end.
Your PM-DLGD230711-V1.0 "techno gibberish" suggests of a U-processor's involvement and its program version.
For all past times, I don't ever relate the use of a 8 pin DIP . . . being used on case styles for U-processors, nor does the back board shot reveal any epoxy blob COB, being utilized.
HOWEVER the black LED and PHOTOCELL might be mounted atop a U-processor chip ? Which I can not make out.
If you are willing to take a DVM, placed in its DC voltage range and log down the voltage on every pin of the 8 pin unit and then to a hand wave to see what the voltages change to, in the opposite state (on or off) .
Then we might see if the use of a 1-5k resistor connected to +5 or ground and applied to the ascertained chip pin, to assimilate a logic HIGH or LOW might also toggle LED's between on and off.
Then, the use of the delay imparted by a simple dedicated clock reset IC, to toggle the LED lights off after either a power up or power off condition . . . . . according to whichever you would need .
BTW . . . .to pre answer to the question of all of the YO-YO's thinking that U1? is being a 555.
Pin 3 would be LED drive and pin 8 is power, while pin 1 is ground.
SEE BELOW . . . .
THAAAAAAASSSSSSITT !
73's de Edd . . . . .
A five year olds initial / early on perception of the GOLDEN RULE . . . .
Do one to others as others would do one to you.
wizzard73
Apr 4, 2024
5
@73's de Edd Oh my Goodness.... that is the most complete answer I received in my entire life... I will try to answer your questions:
the LED strip will be connected to a switchable AC power source. Also I don't want to have the LED strip ON after an electricity outage/recovery.
Is a simple 5V 2A USB connector (not a piece of computer equipment), connected directly to the AC power source
yes, there is a separate power switch involved automated by Shelly 2.5
wizzard73
Apr 4, 2024
5
The initial problem was that at the place where this LED strip has to be installed, only power source from a switch is available. eventually I decided to pass through a separate power source which is always on and not from the switch
