Linear lab amp DC-30MHz?
John Devereux
Rich Grise said:
Gonna take a HELL of a big pi-network to go down to "DC". ;-)
.. --- L---
.. C C
Ancient_Hacker
Not that bad, if you dip it in liquid Helium. IIRC there's such a
thing as a superconducting DC transformer. But I usually like my Pi
warmed up. :)
Ancient_Hacker
Years ago I stumbled onto what looked like a forced-air furnace at a
junkyard. Well, it did have a big fan, but the heating elements were
48 4CX250B toobs, all in a distributed-amplifier topology. The thing
was too heavy to drag home. And what would the wife say?
Rich Grise, but drunk
Where's this junkyard at? How deep could they be? ;-)
Cheers!
Rich
-----BEGIN GEEK CODE BLOCK-----
Version: 3.1
GAT(E P) dpu s: a++ C++@ P+ L++>+ !E W+ N++ o? K? w-- !O !M !V PS+++
PE Y+ PGP- t 5+++)-; X- R- tv+ b+ DI++++>+ D-? G e+$ h+ r-- z+
------END GEEK CODE BLOCK------
Joseph2k
Joerg said:
Hello Richard,
If you don't want to build it yourself check out companies like these:
http://www.wavecontrol.com/index2004.php?p=pantalla&pant=RF Amplifiers %20DC%20-%201GHz&idm=385
They claim that the 50WD1000 does 50W from DC to a GHz. It is probably
really expensive, the size of a book cabinet and you may need a crane to
get it into the building.
Regards, Joerg
I would consider some of the Apex devices, they have have high bandwidth
power amplifiers. Some of them are pretty impressive.
O
Oliver Betz
Richard Kayman said:
What are the most cost effective options for buying or building a
linear amp for general lab work that will do DC up into the early tens
of Mhz?
http://www.ophirrf.com/ sells DC powered modules (e.g. 5303055), but
they are still around 3500USD. And you don't get DC.
Oliver
Joerg
Hello Oliver,
If you ever need something this big consider buying a used ENI amp. They
are very wideband and I have used them in susceptibility tests. That way
we also found some glitches that they thought were 'digital', so
sometimes clients wanted to own one afterwards and usually we could find
a used one.
However, one has to know this RF power stuff. Otherwise somebody in a
uniform might knock on the door some day.
Regards, Joerg
O
Oliver Betz
[20W wideband amp]
I'm already considering this, but it seems that people don't sell many
of them.
at lower frequencies (the OP wrote "early tens of Mhz", that's also my
range), the risk is low.
Oliver
Joerg
Hello Oliver,
of them.
Yes, it's tough. Keep your eyes peeled for when an EMI lab shuts down
somewhere in Europe. Most likely they have some. For me buying equipment
from businesses that closed has yielded the best deals for lab gear.
That depends on where your location is. Maritime and air traffic still
uses shortwave a lot across the oceans. They don't like it when somebody
messes with their communications.
One common trick to avoid trouble is to try to do most measurements or
at least the initial ones on an ISM frequency. 13.56MHz is one of my
favorites.
Regards, Joerg
