13V/us isn't that slow.audioguru said:An LM358 is very slow
Then....Which op-amp should I use?????audioguru said:Hi Alun,
An old LM358 is half an old LM324. They are about the 1st low-power opamps ever made so sure they are darn slow.
They slew 2.5V in 5us which is only 0.5V/us. Their output is slew-rate limited above only 5kHz. :'(
Your P-channel Mosfet in a low-dropout regulator is a good idea to keep the supply voltage of the opamp down to its max rating. ;D
i SEE....It 's 4.5M high speed Op- ampAlun said:Try the CA3140E and have a go with my idea if have any p-chanel MOSFETs available.
What’s the DAC look like? How many bits?
Thanks a lot...But I have few question about this....audioguru said:Hi Cyw,
You didn't finish your circuit with the important stuff I mentioned, so I added/changed a few things.
About the only thing that remains is adding current limiting or regulation. If you draw too much current or short the output, it will blow-up! ;D
It is 12BIT DAC 0-10VStaigen said:Hey boys, and old man Audioguru
Lets stop a while and think, and dont rush away
There is so much we dont know about this regulator, but there is at least some data given. We know:
The input voltage is 40 Volts
The output voltage: 0 to 30 Volts, depending on Vref
Vref: 0 to 10 Volt from a DAC
Something we dont know, and i belive we must know:
Output current
In some instances the output resistance of the DAC
Something that would be nice to know:
Data about the DAC(not necessarily needed, except above)
The 3140 IC have a max voltage rating of only 36 Volt, so why stress it above that, use an another IC
Audioguru, i have seen a lot of commercially designed circuits with 2N3055, both switched and linear, and the resistor between base and emitter has been in the range of 100 to 220 ohms, dont you think that 10 K is a little bit high? And also the resistor between the 2N3053:s base and the output, its usally betwwen 1 K and 1,5 K? What is the purpose of the 1 K resistor between the base of the 2N3053 and the collector of the 2N3906? And no offset adjust?
Alun, your circuit is a good one, exept that the 3140 IC are not guaranteed for 40 Volts and there is no voltage limit on the MOSFET:s gate! And no offset adjust.
Whats so wrong with the original circuit, exept that it have the wrong IC and no resistors from the base to the emitter on some transistors? It also lack protection for the base on one transistor and it have no offset adjustment! But, it have output short protection, so it is much safer! The shematic is here under:
//Staigen
Use a higher voltage IC or a separate power supply for the IC.Staigen said:Alun, your circuit is a good one, exept that the 3140 IC are not guaranteed for 40 Volts
Just add a zenner, see attachment.and there is no voltage limit on the MOSFET:s gate!
Why do you need to offfset adjust? Any error in the output can be taken care of with a small trimmer resistor.And no offset adjust.
You could also power the IC from a zenner diode shunt regulator to get round the voltage problem but this won't work with my MOSFET circuit, however I can solve this problem too.Whats so wrong with the original circuit, exept that it have the wrong IC and no resistors from the base to the emitter on some transistors?
Even though you haven't considered limiting the current at this stage it's still very important to know the magnitude, this will give you an idea of the componant ratings the design techniques you should use. By looking at the componats you've used and your origional design I assume you want the output current to be around 10 amps or so, is the correct?current limit I will design later
I want the output current to be around 2 to 3 AMPS.....Your 's enclose can the output achieve to 0-30V???Alun said:Use a higher voltage IC or a separate power supply for the IC.
I chose a MOSFET because it's simpler, will work out cheaper, has a lower drop out voltage (not important here though), will have a lower quesant current and a far better transient response.
