audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
Hi nearly old man Staigen,
You are absolutely correct! I was way off with my selection of high-value "turn-off" resistors for the output transistors in my "fixed" circuit. I have now chosen lower value resistors based on what is inside a TIP120 darlington.
I used a 1k resistor in series with the collector of the 2N3906 to limit its collector current and dissipation if the project's output is shorted. It will still provide enough drive to the output transistors to blow a fuse if the output is shorted.
I think the circuit can deliver 30V at 1.5A with a 34V supply to protect the 36V max-rated opamp.
It would be fun to try to stop this extremely high gain circuit from oscillating. ;D
Hi Alun and Cyw,
I don't think a single 2N3055 or power Mosfet can dissipate more than about 60W even on a pretty big heatsink. Therefore the max current is only 2A at low output voltages. That's why I proposed using 2 output transistors in our 0V-30V modified project for 3A output, and using 3 output transistors on our modified for 5A project.
Hi Alun and Cyw,
