I'm making a bench supply out of the 5A Constant voltage/current circuit on page 16 of the LM317 datasheet http://cache.national.com/ds/LM/LM117.pdf.
I've replaced the MJ4502 transistor with a MJ2955 TO-3 transistor.
Thing thing works fine for current up to 1A, adjusted via the pot. But once u put a load on there with current adjustment more than 1A, the 2955 transistor just shorts out and dumps the whole 5A across it. If u leave this going long enough it smokes the 3.3ohm resistor as well.
I find this strange since the transitor is rated to 15A, and the circuit is meant to go up to 5A (though i've only supplied it with 2A max while testing).
I've got the transitor on a small diamond shaped finned heatsink, though this seems insufficient. Is this my problem?
Also for short crcuit protection, diodes can be added to the circuit. Namely diode acoss the out and input of the 317 regulator with the negative end connected to the input, and another across the adjust and output - negative end connected to the output.
This circuit lacks these diodes, so I take it that is is not short circuit proof? Whould I be able to add them into the circuit without affcting the operation of the opamp for current limiting?
Should the 3.3ohm resistor be more then ur standard 1/2W variant? i.e. 5W
