looking for 12vdc automotive relays
Dan
I found some really cheap ones HKE CMA31 a couple years ago from a surplus
house but that's what they were, so there's probably no more. I need 12vdc
coil and 10-30amp 12vdc contactors. Any tips would be appreciated.
Dan
dansteely2001 AT yahoo DOTCOM
These are all in the standard 1-inch (2.5-cm) cube with 5 0.25" (0.63 cm)
terminals, and usually have 30 A ratings on the normally open (30/87)
contacts:
Mouser http://www.mouser.com/
526-R51-5D40-12 ~$6.50 NTE no mounting tab
Digi-Key http://www.digikey.com/
Z982-ND $5.10 Omron mounting tab
Z981-ND $5.20 Omron no mounting tab
PB527-ND $3.91 P&B mounting tab
PB536-ND $3.60 P&B no mounting tab
Del City http://www.delcity.net/
73980 $2.36 Hella* mounting tab
73984 $2.46 Hella* no mounting tab
73570 $1.24 socket to fit any of the above relays
(*They don't specify Hella, but that's what's in the pictures and that's
what I've gotten on a couple of orders)
The only problem with Del City is that they have a $25 minimum order. If
you need a bunch of relays, though, they have a good price.
Standard disclaimers apply. I don't get money from any of the companies
mentioned.
Matt Roberds
Dan
See:
http://www.allcorp.com/
Search on relay.
Rly-630 and Rly-631 are SPDT automotive relays
rated at 12V coil, 30/40 amps contacts
Cost is $2.25 each.
Rly-351 is the same, except contacts rating is 20/30
and the price is $2.40
