Use a 2200 uF. This is very common, and is used often. These caps have about
a 20% tolerance. You can vary the value by a fair extent, and it will work.
I am assuming this is a filter cap. If so, you can probably go to a 3300 in
most cases, if it will mechanically fit.
If you want to be exact, and you have the space, you can put 2 of 1000 uF
caps in parallel.
Jerry G.
I've checked all my suppliers and can't find any 2000uf electrolytic caps in
30volt or 35volt. Any help or suggestions appreciated.
George
