Looking for "alter" command help
Tom Bruhns
Hi all,
I'm using a pretty vanilla Berkeley Spice 3f4. The interactive
interpreter manual documents an "alter" command. Long ago I managed
to divine that for simple alterations of single-parameter components
such as resistors, I need to put in an equals-sign instead of just a
space between the device and the value, at least in my version, but
I'll be darned if I can figure out how to alter one parameter of a
multi-parameter component. In particular I have an independent
source:
vin 1 0 dc 0 ac 1
whose AC magnitude I wish to alter. Things I've tried so far that
don't work:
alter vin[ac]=0
alter @vin[ac]=0
alter @vin[ac] = 0
alter #vin[ac]=0
alter @vin(ac)=0
alter @vin[AC]=0
alter @vin[ac]=[ 0 0 ] (thinking maybe it needs both mag and phase)
alter @vin[ac]=(0;0)
Most of these simply kill the SPICE session. alter@vin[ac]=0 seems to
come closest to working, but SPICE complains,
Error: no such parameter ac.
Error: no such parameter ac].
What's the magic incantation for this puppy?
Cheers,
Tom
Charles DH Williams
source:
vin 1 0 dc 0 ac 1alter vin[ac]=0
alter @vin[ac]=0
alter @vin[ac] = 0
alter #vin[ac]=0
alter @vin(ac)=0
alter @vin[AC]=0
The following should work:
alter @vin[ac] = 0
but is affected by several bugs in the Berkeley code. However, ISTR that
the alternative syntax
alter dev param = expression
i.e.
alter vin ac = 0
will work okay on unfixed code.
Charles.
Tom Bruhns
Hallelujah! Thank you, Charles. That (second form) did it. The one
you say should work does not on my version. Now that I look at the
documentation, I don't know why it didn't occur to me to try that
second form; it's just what the docs say except with an added "=" like
I have to do for the single-parameter devices anyway. Neurons shorted
out from frustration at the ones that didn't work?
Cheers,
Tom
source:
alter @vin[ac]=0
alter @vin[ac] = 0
alter #vin[ac]=0
alter @vin(ac)=0
alter @vin[AC]=0
alter @vin[ac] = 0
i.e.
alter vin ac = 0
Charles.
