Looking for an equivalent diode
tommis15
Apr 15, 2014
20
I am working on fixing a power supply unit. I know it might not work but, better to try than to throw it out. :)
Anyways I came across a diode called RK-19... it cooked.
Datasheet at http://pdf.datasheetcatalog.com/datasheet/eic/RK19.pdf
I can't seem to find this diode anywhere. On the datasheet it says UPDATED: September 12th 1998 so I could only assume it's old and outdated.
Can someone help me find an equivalent diode... If there is one.
Thanks in advance!
tommis15
Apr 15, 2014
20
Thanks for the help... I used a multimeter to check the diode and there is a resistance across the diode... I wonder if I could still use it. Should I still give it a try?
