Looking for good video surveillance software...
sorka
Having a hard time finding software that meets the following
requirements:
1) Multiple cameras from both video capture cards and IP netcams.
2) Motion detection - Must be quick and evaluated at each frame during
an event. The really crappy software will stop detection after
recording starts until the pre-defined recording time elapses.
3) Motion detection mask with hi resolution. An example of one that
would not be acceptable is a limited 5x5 mask.
4) Must be able to trigger an application based on a motion detection
event.
5) All the typical alerts - email, pager, phone, etc.
6) Remote log viewing. I have cable modem, so POTS integration is not a
requirement.
7) Must be integrated. None of this running multiple instances of the
same software for each camera.
8) Must be stable and reliable. Can't crash, or fill up the hard drive.
So far, the only package I'm aware of that meets these requirements is
go1984, but it's $850 for the Enterprise edition.
I've looked at a ton of applications, but none of them do *all* of
these.
It's a real shame that Gotcha! never evolved. It had the best motion
detection, but the software hasn't been updated in 8 years, so it's
pretty much dead.
Pluses:
1) Multiple motion detection zones in one camera with seperate
sensivity and alarm configurations for each. i.e. I want to record when
the car drives out in front in our cul-de-sac, but I only want to be
informed when someone walks up the walkway.
2) Auto tuning for plants. A real good detection algorithm will tune
out plants that blow in the wind so that they don't require masking off
seperately.
3) Object detection and tracking. Knowing the difference between a
human, vehicle, and a dog, etc. Obviously this is pie in the sky type
stuff.
Jackcsg
It records in JPEG and or MJEG. Playback video is packaged in .avi so it can
be viewed from a standard windows media player.
SF9026
have you tried X guard
can
Jackcsg
That's what it is. The software can record video from IP Cameras, or
Servers.
Jackcsg
Do you have a link? Never heard of X Guard.
Fill us in.....
SF9026
a.. Display and record each camera or any video signal
simultaneously.
b.. Adjustable video source (brightness, contrast and etc.),
quality, alarm, motion detection area.
c.. Motion Detection: watch for movement detected and record the
video clips
d.. Preview size adjustable.
e.. Image quality and Compression ratio adjustable.
f.. Allow the users to define the environment that they do not wish
to observe, by adjusting mask area and sensitivity.
g.. Video file database management, delete, backup or review.
h.. Storage Recycle: When running out of disk space, you can delete
the data of earliest date.
i.. Remote view through TCP/IP or IPX protocol (Internet/Intranet),
fixed IP is recommended.
j.. Remote view through modem communication protocol (Only for 4
port).
k.. Supports following network architecture: T1, T3, ADSL, ISDN,
PSTN, Cable modem, Hi building etc.
l.. Compression ratio (without motion detection)
m.. High Image Quality:4:1
n.. Low Image Quality:30:1
o.. Every camera frame rates:
Server: 4 port: 3.0 to 5.0 fps
9 port : 1.5 to 2.0 fps
16 port : 1.5 to 2.0 fps
a.. Remote: 10/N fps (10-Base LAN)
b.. Remote: 1~16fpm(modem communication) only for 4 port
Detailed description of software use and features for 4 Port
Specifications
a.. Hardware: Grand Bt878 Video Capture Card
b.. Fully PCI 2.1 compliant
c.. Supports the following video formats which including NTSC-M,
NTSC-Japan PAL-B,D,G,H, PAL -M, PAL-N, SECAM, PAL-NC.
d.. Supports 4,9, or 16 composite video input connectors
e.. Bundled with the following Software:
1.. Grand X-Guard (Record and Display)
2.. Remote Camera System (Internet/Intranet or modem
communication)
3.. Grand File Database.
f.. Supports 98/ME/2000/XP (for 4 Port only). Not compatible with
Windows 2000 Server Edition.
g.. Supports Win2000 or Win XP (4, 9 & 16 port).
System Requirements
a.. Intel Pentium II 500 or above, Pentium III 800 is recommended.
Not 100% compatible with Celeron or non-Intel-based processors.
b.. Microsoft Win 98/ME (for 4 Port only) 2000/XP (4, 9 and 16
port). Not compatible with Windows 2000 Server Edition.
c.. Audio output: sound card
d.. Network: Ethernet network card or Modem
e.. Hard disk space: Plenty of disk storage for recording. At least
20 GB
f.. System RAM: 128 MB or above Display card: 16 bit high color
SF9026
http://www.grandtec.com/xguard.htm
simultaneously.
video clips
port).
Specifications
communication)
System Requirements
20 GB
Matt Ion
Take a look at Video Insight's offerings at www.videoinsight.net - I
think it handles all or almost all of your requirements nicely, and at
least a couple of the plusses.
Only package I've worked with that does motion tracking is CAMACC's
Vigil system, but I'm not sure if they sell the software separately,
only only sell complete systems. Check them out at www.camacc.com
requirements:
event.
requirement.
these.
pretty much dead.
Pluses:
seperately.
stuff.
avast! Antivirus: Outbound message clean.
Virus Database (VPS): 0538-2, 09/19/2005
Tested on: 9/19/2005 9:32:44 PM
avast! - copyright (c) 1988-2005 ALWIL Software.
http://www.avast.com
